| Jason74914 |
Feb 4 2016, 09:16 AM
Member ![]() ![]() Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None |
I want to install an inline fuel pressure gauge in my 1.8L to monitor things while I diagnose some issues. Where is the proper place to do this for monitoring fuel pressure?
Diagram from PP: http://www.pelicanparts.com/914/technical_...4_18FI_diag.htm |
| malcolm2 |
Feb 4 2016, 12:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
It was not easy to find something that screwed into the factory rail between cylinders, so I went to Harbor Freight and bought a fuel pressure tester.... Harbor Freight Link on sale for $20.
In the engine bay, I cut my new fuel line just past the hard line coming from the pump. I spliced in the silver union in the center of the picture. Did not use the hose clamps in the picture, used the German type. Then screwed the gauge into the new rail. Registers about 40. Alittle jumpy at idle, but very still at 3k rev. ![]() |
| Jason74914 |
Feb 6 2016, 09:53 AM
It was not easy to find something that screwed into the factory rail between cylinders, so I went to Harbor Freight and bought a fuel pressure tester.... Harbor Freight Link on sale for $20. In the engine bay, I cut my new fuel line just past the hard line coming from the pump. I spliced in the silver union in the center of the picture. Did not use the hose clamps in the picture, used the German type. Then screwed the gauge into the new rail. Registers about 40. Alittle jumpy at idle, but very still at 3k rev. ![]() I have that same fuel pressure gauge tool kit. The difference with the JEGS gauge is that it is fluid-filled, which keeps the needle from bouncing around. |
Jason74914 Best place for inline fuel pressure gauge? Feb 4 2016, 09:16 AM
76-914 Check your fuel rail on the left side. Many have a... Feb 4 2016, 10:46 AM
pete000 I just tapped the drivers side diagnostic port on ... Feb 4 2016, 12:11 PM
PlantMan
It was not easy to find something that screwed in... Feb 4 2016, 02:54 PM
Dave_Darling You don't screw anything onto the fuel rail, y... Feb 4 2016, 08:39 PM
Jason74914 Thanks all. I don't intend to try to screw int... Feb 5 2016, 09:12 AM
scott_in_nh I cut the fuel line going to the cold start inject... Feb 5 2016, 12:03 PM
pete000 Let us know what pressures you see when you get it... Feb 5 2016, 12:11 PM
pete000 Here are some pictures of how I routed mine. Feb 8 2016, 07:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 6th March 2026 - 10:55 PM |
