| Series9 |
Feb 10 2016, 01:44 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,459 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
As a VW/Porsche professional, there are always a few things you think about. You know, common things you haven't done yet. Go ahead and laugh: I'm changing my first swing-axle transmission today. 1965 T-34. First, here are my thoughts on the swing-axle design: (IMG:style_emoticons/default/dry.gif) Here's where I need help: The left and right sides had different spacers between the wheel bearing and the hub. Which one is correct? They are very different thicknesses, and one has an inside chamfer while the other has an outside. I took them both off before I noticed the difference, so I can't tell you which was where. What I can tell you it the LR brakes were totally covered in gear oil. Help, please. (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
| 914fahrer |
Feb 10 2016, 02:08 PM
Member ![]() ![]() Group: Members Posts: 103 Joined: 12-November 14 From: Berlin/Germany Member No.: 18,115 Region Association: Germany |
Hello ,
one part look`s like this one. https://www.deimosaircooled.com/split-scree...e-111-501-303-b Gruss Ralf |
Series9 I Admit It, I Haven't Seen it All...... Feb 10 2016, 01:44 PM
Mark Henry You need 2 of the left, the bevel goes against the... Feb 10 2016, 02:06 PM
Series9
Hello ,
https... Feb 10 2016, 02:45 PM
Mark Henry Sorry there is two per axle here's a good pic ... Feb 10 2016, 02:15 PM
Mark Henry Joe if you plan on servicing VW beetles get the 19... Feb 10 2016, 02:28 PM
Series9
Joe if you plan on servicing VW beetles get the 1... Feb 10 2016, 02:51 PM
Series9 Tubes are both 22 1/4"
Axles are both 28 3/8... Feb 10 2016, 02:44 PM
Series9 I was really hoping the shorter one was correct.
... Feb 10 2016, 03:30 PM
Series9 Nothing to see here.....
I went to the lathe anyw... Feb 10 2016, 04:50 PM
Series9 Thank you for the help in determining which spacer... Feb 10 2016, 04:53 PM
Series9 Whooops! Well that's not right.
Look at ... Feb 13 2016, 10:30 AM
r_towle I recall that the nose on the drums does have vari... Feb 13 2016, 10:35 AM
Series9
I recall that the nose on the drums does have var... Feb 13 2016, 10:47 AM
914fahrer I found this for a rear drum,sorry only in german
... Feb 13 2016, 10:49 AM
r_towle Just for grins, look at th front drums versus the ... Feb 13 2016, 11:00 AM
Series9 And then....
The bearing cap is none of these: Feb 13 2016, 11:20 AM
Series9 And then.....
The rear drums have Type I part nu... Feb 13 2016, 11:45 AM
Mark Henry Hmmmm... The T34 is an oddball.
The 5 bolt drums ... Feb 13 2016, 12:29 PM
Series9
The 5 bolt drums... Feb 13 2016, 03:11 PM
r_towle Fire up the lathe. Feb 13 2016, 03:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 06:48 AM |
