> I Admit It, I Haven't Seen it All......, Help now, laugh later.....
Series9
post Feb 10 2016, 01:44 PM
Lesbians taste like chicken.
As a VW/Porsche professional, there are always a few things you think about. You know, common things you haven't done yet.
Go ahead and laugh: I'm changing my first swing-axle transmission today. 1965 T-34.
First, here are my thoughts on the swing-axle design: (IMG:style_emoticons/default/dry.gif)
Here's where I need help: The left and right sides had different spacers between the wheel bearing and the hub.
Which one is correct? They are very different thicknesses, and one has an inside chamfer while the other has an outside.
I took them both off before I noticed the difference, so I can't tell you which was where. What I can tell you it the LR brakes were totally covered in gear oil.
Help, please.
Mark Henry
post Feb 10 2016, 02:28 PM
that's what I do!
Joe if you plan on servicing VW beetles get the 1966-1970 bentley manual as it covers both swing and IRS standard trans, plus autostick trannies.
Servicing beetles you can get away with just this one manual and the net.
I'd also get the Bentley transporter and vanagon manuals
All other aftermarket manuals suck.
Series9
post Feb 10 2016, 02:51 PM
QUOTE(Mark Henry @ Feb 10 2016, 03:28 PM) *
I have the Bentley for the Vans and Vanagon. I also found the same image you posted for this project, but nothing shows dimensions for the spacer.
Series9   I Admit It, I Haven't Seen it All......   Feb 10 2016, 01:44 PM
Mark Henry   You need 2 of the left, the bevel goes against the...   Feb 10 2016, 02:06 PM
914fahrer   Hello , one part look`s like this one. https:...   Feb 10 2016, 02:08 PM
Series9   Hello , one part look`s like this one. https...   Feb 10 2016, 02:45 PM
Mark Henry   Sorry there is two per axle here's a good pic ...   Feb 10 2016, 02:15 PM
Mark Henry   Joe if you plan on servicing VW beetles get the 19...   Feb 10 2016, 02:28 PM
Series9   Joe if you plan on servicing VW beetles get the 1...   Feb 10 2016, 02:51 PM
Series9   Tubes are both 22 1/4" Axles are both 28 3/8...   Feb 10 2016, 02:44 PM
Series9   I was really hoping the shorter one was correct. ...   Feb 10 2016, 03:30 PM
Series9   Nothing to see here..... I went to the lathe anyw...   Feb 10 2016, 04:50 PM
Series9   Thank you for the help in determining which spacer...   Feb 10 2016, 04:53 PM
Series9   Whooops! Well that's not right. Look at ...   Feb 13 2016, 10:30 AM
r_towle   I recall that the nose on the drums does have vari...   Feb 13 2016, 10:35 AM
Series9   I recall that the nose on the drums does have var...   Feb 13 2016, 10:47 AM
914fahrer   I found this for a rear drum,sorry only in german ...   Feb 13 2016, 10:49 AM
r_towle   Just for grins, look at th front drums versus the ...   Feb 13 2016, 11:00 AM
Series9   And then.... The bearing cap is none of these:   Feb 13 2016, 11:20 AM
Series9   And then..... The rear drums have Type I part nu...   Feb 13 2016, 11:45 AM
Mark Henry   Hmmmm... The T34 is an oddball. The 5 bolt drums ...   Feb 13 2016, 12:29 PM
Series9   Hmmmm... The T34 is an oddball. The 5 bolt drums...   Feb 13 2016, 03:11 PM
r_towle   Fire up the lathe.   Feb 13 2016, 03:15 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 06:48 AM
