| jack20 |
Feb 8 2016, 08:00 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California
I'm doing suspension and brake work this winter. After mounting and dismounting the wheels several times I finally figured out something most of you have probably known forever.
I went to ACE and bought two bolts that match the thread of the lug bolts and cut the heads off. I've always been a late bloomer... Next I'll figure out how to post a photo in the correct orientation (IMG:style_emoticons/default/idea.gif) |
| rhodyguy |
Feb 9 2016, 11:04 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i ALWAYS leave one of the floor jacks raised to just touching as a safety back up no matter which type of stand i'm using. like a fall arresting harness. you'll never need it until you try to fly and have failed to attach yourself to one. then, if you're lucky, you only have to endure a little pain.
| Randal |
Feb 11 2016, 01:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
i ALWAYS leave one of the floor jacks raised to just touching as a safety back up no matter which type of stand i'm using. like a fall arresting harness. you'll never need it until you try to fly and have failed to attach yourself to one. then, if you're lucky, you only have to endure a little pain. Backups are good. I ALWAYS have my floor jack just touching somewhere when I use jack stands. |
| Randal |
Feb 11 2016, 01:14 PM
i ALWAYS leave one of the floor jacks raised to just touching as a safety back up no matter which type of stand i'm using. like a fall arresting harness. you'll never need it until you try to fly and have failed to attach yourself to one. then, if you're lucky, you only have to endure a little pain. Backups are good. I ALWAYS have my floor jack just touching somewhere when I use jack stands. Of course with the D Sport I've made a permanent table for holding the car at the right height. |
jack20 Should have done this long ago... Feb 8 2016, 08:00 PM
Bruce Hinds So, why did you do that? Just to line it up? That... Feb 8 2016, 08:06 PM
jack20
So, why did you do that? Just to line it up? Tha... Feb 8 2016, 08:12 PM
Olympic 1.7 Somebody makes knurled studs to do that. but your... Feb 8 2016, 08:24 PM
RickS My 91 Audi came with a plastic stud to help mount ... Feb 8 2016, 10:46 PM
Tom_T Not to burst anybody's bubble, but they've... Feb 9 2016, 12:12 AM
AndyB
Not to burst anybody's bubble, but they'v... Feb 9 2016, 10:20 AM
Elliot Cannon
[quote name='Tom_T' post='2300593' date='Feb 9 20... Feb 11 2016, 12:46 PM
SirAndy I disagree with your statements on those jackstand... Feb 11 2016, 03:36 PM
jack20 Tom,
No burst bubbles. As I said, most of you have... Feb 9 2016, 12:47 AM
Darren C Porsche make GENUINE ones.....
http://suncoastpar... Feb 9 2016, 02:17 AM
rhodyguy Works pretty good for a flat tire on any wheel too... Feb 9 2016, 08:49 AM
The Cabinetmaker Been doing it for years. I just cut the head off a... Feb 9 2016, 09:01 AM
Bartlett 914 RE: Should have done this long ago... Feb 9 2016, 09:18 AM
malcolm2 I have a couple sets of those stands.... one set i... Feb 9 2016, 11:44 AM
rhodyguy You can also use zip ties around the handles and s... Feb 9 2016, 11:56 AM
malcolm2
You can also use zip ties around the handles and ... Feb 11 2016, 10:43 AM
Dave_Darling If i remember correctly, he accidentally hit the r... Feb 11 2016, 03:52 PM
Larmo63 Suspenders AND a belt.
Feb 11 2016, 03:58 PM
r_towle for my whole life I have always laid the tire unde... Feb 11 2016, 04:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 01:12 PM |
