| jmitro |
Feb 12 2016, 11:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
two questions about using weld thru primer, (assuming that proper usage is spraying primer on the backside of two adjoining pieces so that primer covers the bare metal that cannot be accessed once welding is completed);
1. Do you change the weld settings on the welder? It welds terribly with poor penetration. Or do you grind off the primer from the anticipated weld spot? If so, then it's defeating the purpose of weld-thru primer, is it not? it leaves bare metal. 2. After welding is complete, do you grind off the exposed weld-thru primer and replace it with POR-15 or primer of choice? |
| bretth |
Feb 12 2016, 12:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
My experience with weld through primer has been that it makes for awful welds. So my use of it was to mask off areas that are going to be welded and then spray it everywhere else.
Brett |
jmitro how to use weld-thru primer Feb 12 2016, 11:44 AM
76-914 Try putting it on a little thinner. It helps. Feb 12 2016, 01:21 PM
SirAndy Try putting it on a little thinner. It helps.
And... Feb 12 2016, 01:54 PM
Elliot Cannon
An... Feb 12 2016, 02:45 PM
r_towle
[quote name='SirAndy' post='2302214' date='Feb 12... Feb 12 2016, 03:16 PM
doug_b_928 From what I have seen, people spray it on what wil... Feb 12 2016, 02:46 PM
Bartlett 914 The fumes are from the zinc in the primer. Burning... Feb 12 2016, 03:21 PM
r_towle I spray on the primer, then grind off the spot wel... Feb 12 2016, 03:28 PM
Jeff Hail The best method is to coat both pieces that face e... Feb 12 2016, 08:35 PM
914forme
The best method is to coat both pieces that face ... Feb 13 2016, 11:20 AM
larryM consider this expert advice
Ron Covell advice
... Feb 12 2016, 10:30 PM
jmitro :agree:
no doubt! Thank you so much for all... Feb 13 2016, 11:58 AM
DirtyCossack I have some brush on stuff that is the king of spl... Feb 13 2016, 07:43 PM
914forme I use Wurth
Zinc Rich Weld Through Primer
Desc... Feb 13 2016, 07:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 02:44 AM |
