> how to use weld-thru primer
jmitro
post Feb 12 2016, 11:44 AM
two questions about using weld thru primer, (assuming that proper usage is spraying primer on the backside of two adjoining pieces so that primer covers the bare metal that cannot be accessed once welding is completed);
1. Do you change the weld settings on the welder? It welds terribly with poor penetration. Or do you grind off the primer from the anticipated weld spot? If so, then it's defeating the purpose of weld-thru primer, is it not? it leaves bare metal.
2. After welding is complete, do you grind off the exposed weld-thru primer and replace it with POR-15 or primer of choice?
post Feb 12 2016, 01:21 PM
Try putting it on a little thinner. It helps.
post Feb 12 2016, 01:54 PM
Resident German
QUOTE(76-914 @ Feb 12 2016, 11:21 AM) *
And don't inhale the fumes while welding ...
(IMG:style_emoticons/default/icon8.gif)
Elliot Cannon
post Feb 12 2016, 02:45 PM
Group: Retired Members
QUOTE(SirAndy @ Feb 12 2016, 11:54 AM) *
I have found that inhaling the fumes improves my welding. Who knew? (IMG:style_emoticons/default/av-943.gif)
- Lo-Fi Version Time is now: 4th March 2026 - 04:12 AM
