> I need carpet
johnpierre
post Jan 22 2016, 11:30 AM
Hey everyone
It is time to dedicate some attention to my, well, you already know don't you. I am looking to replace the original (yes original) carpet. I have been looking on Ebay and can't really tell what the quality is like of the kits that are available. I found one for 75.00 but the seller gave it a 5 out of 10.
There is a supplier in OC califormia that I have spoken to that restores everything porsche and they have the original wool loop kit in original colors but that kit was over 500.00
Does anyone have a recommendation? I want to spend about 150.00 for a charcoal grey or black kit that will fit properly and look not like a crappy after market product until I can afford the real deal.
Any thoughts?
thx -jp-
ps I have a 73 1.7 fuel injected model
johnpierre
post Feb 12 2016, 02:03 PM
BTW
I just ordered a new red handle for the heater lever and have new PRESS red stickers that I purchased from a member to replace the faded ones on the seat belt clicky things.
next on my list is a new wood steering wheel from Nardi and then a new dash.
after which the seats, door panels, and back pad by summer...
then next year suspension and engine redo... goto get this baby in shape....
-jp-
Tom_T
post Feb 12 2016, 03:04 PM
TMI....
QUOTE(johnpierre @ Feb 12 2016, 12:03 PM) *
BTW
after which the seats, door panels, and back bad by summer...
-jp-
jp -
Stoddards sells a new 914 dash repro which is excellent for about $800.
Unless you really drool for a wood steering wheel, you might consider having Dallas Steering Wheel (DSW) or the guy who comes to the Porsche Swap Meet at the Phoenix Club in Anaheim in March do a leather recovering - with the extra layer of felt padding under it if you prefer a softer grip &/or thinker rim - on either your current aftermarket 3-spoke or another OE 4-spoke wheel with butterfly horn pad or puck). [I prefer the grip & feel of leather myself]
Autos International in Escondido or World Upholstery in Ventura & Lakewell.com in Belgium all sell 914 upholstery kits in the smooth beige/tan leatherette (only Lakewell has the tan basketweave) - but not sure which also does the corduroy inserts like yours. I suggest get them all to send you samples now, so you can choose which you prefer.
If you're not confident in doing your own reupholstery, then AI & WU does top quality interiors, but a local upholstery shop which does classic sports cars & rods can probably do them for you too, if you want to just order the bulk fabric or kits. Not sure who is near you in Culver City, but I know a couple of shops in HB that I'd trust with interior work. If you need new foam, then AI or WU may be easier, but their prices are way up there too.
I had my OE Recaro front seats in my 85 BMW 325e 2dr coupe redone in in smooth & perforated/patterned-insert Perl Biege vinyl in 2014 by one of the HB shops & it was about $1200 including redoing the leather steering wheel & rebuilding the operable seats/backs/seat-shocks (it has a back seat, unlike a 914 (IMG:style_emoticons/default/biggrin.gif) ). It's seats are more complex, required custom stamping of the detail in the inserts, & probably had more material - than a 914 seat
So the price may be less for your 914 & they may have a match for the vinyl & corduroy at such local shops too, bit then you have to add in more for the backpad, center cushion & door panels to get it to match. AFAIK Lakwewell is the only one that still has the 914 Beige in the 70-74 (excl 71) Basketweave for all door & some seat inserts, so I bought both smooth & basketweave yardage from them so that both would match, sufficient to do it all by a local shop or AI at some point (email them for yards needed).
Suspension - IMHO Koni Reds or Bilstein R shocks & F strut inserts, & the poly street bushings all around - unless you plan to race or AX with it, cuz their race bushings are harder & rough riding on the street for DD/pleasure use. Ditto if you need springs or torsion bars - stick with stock lbs. (0 lbs for a 73 1.& IIRC & definitely for a 2L) - unless you're racing/AXing - then you'll ride rougher on street use.
The better idea to improve handling on a 1.7 without the anti-sway bars is to add a used set of the OE ones or new Elephant sway bar kits F & R. If you do tie-rodss, then stick with either the stock or Trubo-tie-rod upgrade from Lemforder only - don't waste you money on the knock offs - they're built cheap too! Don't forget fresh wheel bearings (SWF or other German OEMs only) + brake lines & Porterfield R4S brake pads from PMB.
Engine - Do a bunch of research first on what you want out of the rebuild, & check out the 1911cc upbuilds, & what places like FAT Performance here in Orange does with Type IV motors. I don't know how much Raby has on his website, nor if someone like McMark at Original Customs can build a 2056 from your 1.7 - soo check around alot. A tried & true set-up is better than guessing at what might work, so poll others with 1.7s on here too.
I know other VW & 914 folks who like Der Buggy in Garden Grove, but AASE in Fullerton & Bill Brewster's shop in So. OC are top aircooled Porsche shops. Others may recco some up in LA closer to you, & OTTOs in Venice used to be good, but he passed away & I don't know how good the new guys are. I'd recco my 914 guy of 40+ years Hans, but he won't take any new customers with aircooled cars - only us old customers that still have them.
Tom
johnpierre
post Feb 13 2016, 11:32 AM
QUOTE(Tom_T @ Feb 12 2016, 01:04 PM) *
BTW
-jp-
jp -
Tom
hey Tom
I saw the dash that you are speaking of, but that is just a bit too much. will be purchasing the less expensive one from 914rubber... and a bevy of other items as well, really appreciate you all turning me on this vendor.
in regards to the other points that you have laid out; seats and suspension and engine, such valuable info this thread is becoming my new best friend. ;-)
-jp-
ps attaching the thresholds today... pics to follow...
johnpierre   I need carpet   Jan 22 2016, 11:30 AM
ndfrigi   914rubber.com   Jan 22 2016, 11:32 AM
mepstein   914rubber.com :agree: Unlike the other suggest...   Jan 22 2016, 04:02 PM
Jett   Bought a black German loop set last week from 914R...   Jan 22 2016, 12:39 PM
Tom_T   Three other additional sources to check - Autos I...   Jan 22 2016, 01:54 PM
Tom_T   There is a supplier in OC califormia that I have ...   Jan 22 2016, 02:00 PM
johnpierre   There is a supplier in OC califormia that I have...   Jan 22 2016, 11:47 PM
Tom_T   hey Tom the source in OC was called Auto Internat...   Jan 23 2016, 02:06 PM
johnpierre   hey Tom the source in OC was called Auto Interna...   Jan 24 2016, 03:25 PM
Tom_T   Tom wow your really know your stuff... thank...   Jan 25 2016, 11:59 AM
Mikey914   I use German imported square weave ans well as the...   Jan 22 2016, 03:46 PM
Tom_T   I use German imported square weave ans well as th...   Jan 22 2016, 05:26 PM
johnpierre   I use German imported square weave ans well as th...   Jan 23 2016, 12:01 AM
Larmo63   I was super happy with the Perlon set I bought on ...   Jan 22 2016, 06:22 PM
mepstein   I was super happy with the Perlon set I bought on...   Jan 22 2016, 08:20 PM
Elliot Cannon   Love those hub caps. :D   Jan 22 2016, 07:22 PM
Tom_T   Hey Elliot - do you mean, like these ones Pete Bro...   Jan 22 2016, 08:15 PM
Mikey914   No worries, Just to let you know I will be bringin...   Jan 22 2016, 11:34 PM
johnpierre   Hey everyone Thanks for tall the great and imfor...   Jan 22 2016, 11:58 PM
Mikey914   Yes I am. Sorry I haven't put the picture up y...   Jan 23 2016, 01:10 AM
RobW   I bought a set from Mikey for Dads car. Very happy...   Jan 25 2016, 12:14 PM
johnpierre   ok everyone the carpet experiment was a success. ...   Feb 10 2016, 01:03 PM
Tom_T   Any of the Porsche & other parts houses that h...   Feb 10 2016, 01:23 PM
johnpierre   Any of the Porsche & other parts houses that ...   Feb 10 2016, 01:50 PM
Tom_T   Hey Tom Ok I have seen those and like them. I li...   Feb 10 2016, 02:05 PM
ndfrigi   i bought my used floor mat from a member (Current ...   Feb 10 2016, 03:14 PM
johnpierre   i bought my used floor mat from a member (Current...   Feb 12 2016, 12:23 PM
Tom_T   i bought my used floor mat from a member (Current...   Feb 12 2016, 03:33 PM
turk22   I like the Coco Mat's, indestructible   Feb 10 2016, 05:33 PM
johnpierre   I like the Coco Mat's, indestructible th...   Feb 12 2016, 12:24 PM
Tom_T   Steve - I love the black with the offsetting white...   Feb 10 2016, 06:28 PM
johnpierre   ok everyone here is a little catch up on the carpe...   Feb 12 2016, 12:28 PM
johnpierre   more of the misery....   Feb 12 2016, 12:30 PM
johnpierre   just a bit of paint to cover the old color until i...   Feb 12 2016, 12:31 PM
johnpierre   and now for the finished product :Qarl:   Feb 12 2016, 12:34 PM
johnpierre   mas...   Feb 12 2016, 12:34 PM
johnpierre   Now as you can see i replaced the inside threshold...   Feb 12 2016, 12:46 PM
Tom_T   jp - It looks like your interior was the same or...   Feb 12 2016, 01:56 PM
johnpierre   jp - It looks like your interior was the same o...   Feb 12 2016, 01:59 PM
johnpierre   BTW I just ordered a new red handle for the heate...   Feb 12 2016, 02:03 PM
Tom_T   BTW I just ordered a new red handle for the heat...   Feb 12 2016, 03:04 PM
johnpierre   [quote name='johnpierre' post='2302218' date='Feb...   Feb 13 2016, 11:32 AM
bigkensteele   BTW I just ordered a new red handle for the heat...   Feb 12 2016, 05:50 PM
johnpierre   BTW I just ordered a new red handle for the hea...   Feb 13 2016, 11:40 AM
johnpierre   Me and my 914...   Feb 12 2016, 02:06 PM
Tom_T   Me and my 914... http://www.914world.com/bbs2/upl...   Feb 12 2016, 03:13 PM
johnpierre   [quote name='johnpierre' post='2302219' date='Feb...   Feb 13 2016, 12:08 PM
Mike Fitton   Here are my mats from Lloyd's called Tru-Berbe...   Feb 12 2016, 02:08 PM
johnpierre   Here are my mats from Lloyd's called Tru-Berb...   Feb 12 2016, 02:28 PM
Tom_T   Here are my mats from Lloyd's called Tru-Berb...   Feb 12 2016, 03:47 PM
johnpierre   Here are my mats from Lloyd's called Tru-Ber...   Feb 13 2016, 11:46 AM
Tom_T   Ken - I got some from vendors over on TheSamba.c...   Feb 12 2016, 06:41 PM
Tom_T   Ooops! Duplicate post! :blink:   Feb 12 2016, 06:42 PM
Tom_T   jp - In case you missed this where I added it to ...   Feb 12 2016, 07:59 PM
johnpierre   jp - In case you missed this where I added it to...   Feb 13 2016, 12:10 PM
Tom_T   [quote name='Tom_T' post='2302376' date='Feb 12 2...   Feb 13 2016, 12:26 PM
johnpierre   hey Mark I need the rubber seal for the doors on...   Feb 14 2016, 12:40 PM
Mikey914   Those are the inner door seals on the pinch weld a...   Feb 14 2016, 12:56 PM
johnpierre   Those are the inner door seals on the pinch weld ...   Feb 14 2016, 01:23 PM
Tom_T   :idea: .... El Nino!? :confused: .... just sa...   Feb 14 2016, 01:31 PM
johnpierre   ok everyone here is a another bit of and update. ...   Feb 14 2016, 03:17 PM
- Lo-Fi Version Time is now: 4th November 2026 - 03:24 AM
