| patssle |
Feb 13 2016, 02:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I need to thread tap my bumpers (M12 1.5) to clean out the rust. Is there a socket or extension that works with these? I did the rear bumper with a 8mm socket but it's slipping on the front bumper not being a perfect fit and as the rust is a little tougher.
If very much possible without spending $40 on a socket set that I'll never use again! Thanks! |
| TheCabinetmaker |
Feb 13 2016, 04:19 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You'll do better with a thread chase, not a tap. A tap will cut the threads a little larger making a loose fitting bolt.
patssle Any tips for extending a thead tap? Feb 13 2016, 02:09 PM
Darren C You need a basic collet tap wrench like this...
h... Feb 13 2016, 02:18 PM
Wyvern I have had really good luck just going to the hard... Feb 13 2016, 02:25 PM
zipedadoo What I usually do is find a nut that's a littl... Feb 13 2016, 02:30 PM
patssle
What I usually do is find a nut that's a litt... Feb 14 2016, 07:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th August 2026 - 02:29 AM |
