| -JR- |
Feb 12 2016, 02:08 PM
Life goes faster at 150MPH ![]() ![]() Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I'm in the process of cleaning up a few things on my 75 teen.
One of the jobs was to fix up a sloppy tail shift bushing, THIS ONE. (IMG:http://www.914world.com/bbs2/uploads_offsite/shop.914rubber.com-2055-1455307717.1.jpeg) I purchased a new one from my friends at AutoAtlanta. They inform me I did in fact order the correct one. When I installed this bushing into my side shifter housing it fits loose both on the trans and the shift rod. I've inspected the opening for signs of wear, but it looks to be in good shape and not worn, plus the old bushing did fit tight in the hole. Measuring the transmission opening I get 22mm but the bushing is just a hair under 21mm. I've been advised that I must have had a custom bushing installed. My car is very original and the bushing I cut out looked very old. The bushing I removed looked more like the FIREWALL BUSHING with no "castle" like fingers, it was just one solid ring. Anyone have an idea what I'm running into? |
| TheCabinetmaker |
Feb 13 2016, 04:25 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The shift console most likely has not been machined. Most of them are a little bigger that they were new. Especially if it's been greasy at one time. Grease and dirt combined equal a sanding medium.
| -JR- |
Feb 14 2016, 10:16 PM
The shift console most likely has not been machined. Most of them are a little bigger that they were new. Especially if it's been greasy at one time. Grease and dirt combined equal a sanding medium. I get that, but my old bushing fit tight. So tight that the surfaces were clean when I removed it. Once I have a second opinion on the bushing or transmission hole size, then I'll move forward. Thanks! |
-JR- Side shift bushing issue Feb 12 2016, 02:08 PM
brant your running into the last owners custom bushing..... Feb 12 2016, 02:31 PM
Racer Chris Just JB weld the new bushing in place so it doesn... Feb 12 2016, 02:53 PM
-JR- Anyone know the bushing dimensions for the firewal... Feb 12 2016, 05:47 PM
bretth The subject of the post is side shift bushing but ... Feb 12 2016, 06:25 PM
Mikey914 This what you are looking for? It's part # 914... Feb 12 2016, 08:42 PM
-JR-
This what you are looking for? It's part # 91... Feb 13 2016, 12:06 AM
r_towle They all fit loose.
I made custom bronze ones for ... Feb 12 2016, 09:23 PM
larryM
I made custom bronze ones for mine that are tight... Feb 12 2016, 10:15 PM
porschetub
They all fit loose.
I made custom bronze ones for... Feb 14 2016, 11:55 PM
Larmo63 Use the common (eBay) bronze one in the rear conso... Feb 13 2016, 12:41 AM
-JR-
Use the common (eBay) bronze one in the rear cons... Feb 13 2016, 12:00 PM
cary What Lawrence said.
That's the arrangement th... Feb 13 2016, 09:02 AM
Dave_Darling The hole in the flange wears larger over the years... Feb 13 2016, 11:06 AM
-JR- Got my digital caliper running.
The first bushing... Feb 18 2016, 12:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th September 2026 - 11:22 AM |
