> Help!Is the stock EFI enough, 74 EFI ?'s
Gunn1
post Feb 14 2016, 11:12 AM
I Recently purchased a 74 914 (VIN 4742901009) with what I believe originally had a 2.0 liter installed in it (original engine ID 006765). According to the seller the stock engine had one of the cases busted when it had thrown a rod through it. He went on to say he purchased a case (W0111578 ID found in front of oil filler) and took the remaining parts from the original engine to a shop here in MPLS. there they replaced the main, rod and cam bearings. Blasted-polished the crank and rods. installed a 30mm high flow oil pump. Honed the cylinders & installed and gapped new 94mm ring set. Replaced worn camshaft with a new "IV" mechanical cam. At this point the car is not drivable for structural reasons but the engine starts idles, throttles up down and sounds pretty good. The car came with what looks like the 1.7 type air filter set up and the throttle body which sets horizontal rather than the typical vertically positioned throttle body with the larger square type air filter set up.
With all that important info out of the way, I have many questions. Is this a 1.7 injection installed on a 2.0 engine? if it is, is it a huge deal? Will the 1.7 injection automatically adjust to the larger engines demands for fuel. Most importantly what specs do I use to tune the engine? Thanks Gunn
r_towle
post Feb 15 2016, 03:39 PM
Custom Member
You can use any case with no modifications for all three sets of cylinders.
You need to mill out the 1.7 liter heads to fit the largers cylinders.
The valves, and ports are very different on the 1.7 liter versus the 2.0 liter heads so those heads will never flow like the 2.0 liter heads.
I would suggest for the sake of costs that you get an A/F meter and see how it runs and if the mixture is right.
You will most likely have to be using a custom Djet setup to make it work properly.
Rich
gunn1   Help!Is the stock EFI enough   Feb 14 2016, 11:12 AM
r_towle   No, it will not autmatically do anything, it's...   Feb 14 2016, 11:42 AM
poorsche914   Post some pictures of the engine/engine bay so we ...   Feb 14 2016, 01:02 PM
gunn1   Picture as requested. I know its sort of a mess......   Feb 14 2016, 02:22 PM
poorsche914   If engine is original to the '74 body, spark p...   Feb 14 2016, 02:38 PM
ndfrigi   Picture as requested. I know its sort of a mess.....   Feb 14 2016, 05:56 PM
r_towle   Find the numbers on the ecu, mps, tps, and cht The...   Feb 14 2016, 02:25 PM
gunn1   Picture of ECU. r-towle, I will read the article...   Feb 14 2016, 02:35 PM
3d914   gunn1, here's a link to a site with all the 91...   Feb 14 2016, 03:26 PM
gunn1   Gents This is what is currently in the car, and h...   Feb 14 2016, 04:30 PM
jcd914   3 or 4 studs on the head to intake runners? If th...   Feb 14 2016, 04:56 PM
jcd914   Oh and :wttc:   Feb 14 2016, 04:56 PM
gunn1   Thank you for the welcome to 914 world.... The en...   Feb 14 2016, 05:44 PM
gunn1   this photo was taken by the previous owner. Its ...   Feb 14 2016, 06:06 PM
gunn1   Hold the phone on the 4 versus 3 bolts holding dow...   Feb 14 2016, 06:23 PM
Dave_Darling   I Recently purchased a 74 914 (VIN 4742901009) wi...   Feb 14 2016, 08:49 PM
gunn1   The runners use four nuts for attachment to the he...   Feb 15 2016, 03:44 AM
gunn1   Gents, :WTF: Ok so I spoke with the gentleman th...   Feb 15 2016, 01:12 PM
914time   Welcome to the the World, Gunn! We have a cou...   Feb 15 2016, 02:02 PM
r_towle   You can use any case with no modifications for all...   Feb 15 2016, 03:39 PM
gunn1   One of these days you guys will give me some good ...   Feb 15 2016, 04:07 PM
gunn1   More info!!!!!! The inject...   Feb 15 2016, 05:26 PM
The Cabinetmaker   If you have a 2L crank, rods, cylinders and piston...   Feb 15 2016, 06:00 PM
Bleyseng   So with 1.7l heads bored out to fit 94's you d...   Feb 16 2016, 08:54 AM
gunn1   After doing some more detective work on the car/en...   Feb 16 2016, 07:48 PM
r_towle   The 1.8 heads will fit the 2.0 liter jugs with no ...   Feb 16 2016, 08:39 PM
gunn1   You are correct Rich....I do have a boat load of w...   Feb 17 2016, 12:38 PM
r_towle   in the walking and chewing gum line of thought, if...   Feb 17 2016, 03:20 PM
- Lo-Fi Version Time is now: 25th August 2025 - 05:43 PM
