| mikesjunk |
Feb 15 2016, 07:15 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None |
So waiting on the ignition switch to return so this weekend I had all the parts to go through the shifter. Put in all new bushings front to back and it does feel better and I seem to find all the gears. 4th/5th feel pretty stiff. And when I was under the car it looked like it's rubbing the exhaust.
So didn't have any volunteers to come out and run the gears while I watched underneath so couldn't be in two places at once. I did mark the rods when I disconnected them. This is a tail shift so any tips, tricks, things to look for? Thanks again. |
| mikesjunk |
Feb 16 2016, 07:39 PM
Ok so as above this appears to be the heater supply system not the exhaust. I scooted a bit further under and I see some screws on this piece. I'm guessing these will loosen and I can possibly shift this over to not be rubbing.
BTW. Not a fan of the slotted screws...especially on 40 year old cars. Even in the 70's these couldn't of been very efficient for the assembly plant. Guess I'll do some PB Blaster soaking prior to stripping them out. (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1455673155.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.mikesjunk.com-19423-1455673155.2.jpg) |
mikesjunk Shifter rod rubs exhaust after bushings Feb 15 2016, 07:15 PM
Dave_Darling You say it's a "Frankenstein". In w... Feb 15 2016, 08:20 PM
mikesjunk Frankenstein in the nickname for this car/project ... Feb 16 2016, 04:55 PM
mepstein Finesse first. I have a lot of 1.7 exhaust and shi... Feb 16 2016, 05:00 PM
r_towle Could you post a bigger picture of where it rubs, ... Feb 16 2016, 05:14 PM
mark04usa Looks like the left heater supply pipe is not full... Feb 16 2016, 05:51 PM
mikesjunk Ok so got the wife out to run the gears and it... Feb 16 2016, 05:54 PM
mark04usa Hey, those old German slot head screws work great ... Feb 16 2016, 08:32 PM
r_towle yup, it does look like the heater box is not mount... Feb 17 2016, 03:12 PM
mikesjunk Mark is there a special fat bladed screwdriver tha... Feb 17 2016, 04:29 PM
Dave_Darling
Mark is there a special fat bladed screwdriver th... Feb 17 2016, 10:39 PM
mark04usa
Mark is there a special fat bladed screwdriver th... Feb 18 2016, 12:19 AM
r_towle Harbor freight impact screwdriver is a must have t... Feb 17 2016, 05:15 PM
mikesjunk Thanks I have one around the corner from work. Lo... Feb 17 2016, 05:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 08:29 AM |
