| Amphicar770 |
Jan 2 2016, 11:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,226 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
Hi All,
Looks like I need to replace the CV's on my '74 2.0. I can slide both axles easily from side to side creating the banging noise I was trying to diagnose. I can get two new axle assemblies from Porsche for about $575 with shipping or I can get a set of these from Racer Chris for about $500 ... New Lobro German Type 1 CV Joints adapted for use in 914 rear axle assemblies. Are the Lebro's any better than the original CV joints? COst between the two is close enough that I will go with whatever is better. If the same, I will just get the new ones as there is less to take apart. Thx. Mike |
| Mark Henry |
Jan 2 2016, 03:33 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You can at least see if any of your CV's are serviceable.
Take them apart and run your finger through the outer part bearing groove, if there's a wear divot they're junk. No divot and they can likely be serviced. |
| porschetub |
Feb 17 2016, 01:53 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You can at least see if any of your CV's are serviceable. Take them apart and run your finger through the outer part bearing groove, if there's a wear divot they're junk. No divot and they can likely be serviced. Sage info again Mark,have repacked so many my head spins,found 95% are reusable and the rest are heat marked or galled out,and I must say my experience isn't 914 but many other german cars...makes little difference really. New boots and grease are cheap afterall,note I don't pull them apart just clean them and reassemble,its a time thing not a big money job. |
Amphicar770 CV's, replace or rebuild Jan 2 2016, 11:36 AM
Tom_T If it were me, I'd pop for the extra $75 ... Jan 2 2016, 12:32 PM
mskala
The original Porsche Type IV's CVs on the... Jan 4 2016, 03:29 PM
Amphicar770 Thanks Tom. Just ordered the new ones. Of course... Jan 2 2016, 12:39 PM
914Sixer Porsche had the axles made up. GKN/Lobo has gotte... Jan 2 2016, 03:18 PM
whitetwinturbo :confused: .....so how much side-to-side is ok bef... Jan 2 2016, 09:17 PM
Amphicar770
:confused: .....so how much side-to-side is ok be... Jan 4 2016, 11:33 PM
whitetwinturbo
:confused: .....so how much side-to-side is ok b... Jan 5 2016, 11:58 AM
stinkindiesel I'm in the same boat, and I'm really confu... Jan 4 2016, 02:40 PM
mskala
When I look at replacement CV joints, though,... Jan 4 2016, 03:26 PM
914Sixer Just buy new axle assemblies and get the Porsche w... Jan 4 2016, 06:09 PM
76-914 Not a bad idea to flip 'em if you do re-use th... Jan 4 2016, 06:41 PM
Amphicar770 Looks like the new complete axles are indeed, avai... Jan 7 2016, 10:10 AM
Amphicar770 New axles came in. Looks like they are indeed mad... Jan 9 2016, 01:29 PM
Kansas 914
New axles came in. Looks like they are indeed ma... Jan 9 2016, 02:46 PM
maddin
New axles came in. Looks like they are indeed ma... Feb 17 2016, 03:08 AM
brant Can you show a side by side picture of a new joint... Feb 16 2016, 11:14 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 02:38 AM |
