| BeatNavy |
Feb 17 2015, 05:26 PM
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,962 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region
Getting everything together to install a 2056 into my '72 and swap out the steady, reliable 1.7L I've been running. The 2056 is '73 but came with '74 ECU/MPS combo. The part numbers are 049 on the MPS and 044 on the ECU. Sometimes I'm not sure if I read that ECU/MPS compatibility table on Anders D-Jet site correctly. Is the 049/044 a winning combination?
Also, I've read here that a 2056 really should run with an adjustable MPS. A couple of months ago I converted my 1.7L MPS to adjustable with the Tangerine kit. Any thoughts on whether I could effectively run my MPS (007) just by adjusting it appropriately, or are there other compatibility issues? Or do I need to make that '74 MPS adjustable? Thanks for the help. |
| Bleyseng |
Feb 17 2015, 06:42 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
As long as:
You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! |
| Frank S |
Feb 16 2016, 04:54 AM
Member ![]() ![]() Group: Members Posts: 135 Joined: 15-April 15 From: Wiesbaden, Germany Member No.: 18,632 Region Association: Germany
As long as: You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! I'm confused now. I'm just about to put my new engine together. 2056 cc 9590 cam 8,5/1 CR 037 ECU 017 CHT plus Resistor BUT 043 MPS which I thought can be calibrated like 037 MPS. Is that not possible? Do I need to look out for a 037 or 049 MPS since the 043 can not be adjusted to that settings? Thanks, Frank |
| Bleyseng |
Feb 16 2016, 08:44 AM
As long as: You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! I'm confused now. I'm just about to put my new engine together. 2056 cc 9590 cam 8,5/1 CR 037 ECU 017 CHT plus Resistor BUT 043 MPS which I thought can be calibrated like 037 MPS. Is that not possible? Do I need to look out for a 037 or 049 MPS since the 043 can not be adjusted to that settings? Thanks, Frank It's easier to adjust a MPS using a 044 ECU out of a 74 than a 037 ECU. You have to have enough room (richness) at the WOT and using a 037 barely has enough. Plus you must have the rare 017 CHT with resistor for the idle to work at all with the 037 ECU. |
| Frank S |
Feb 16 2016, 09:39 AM
As long as: You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! I'm confused now. I'm just about to put my new engine together. 2056 cc 9590 cam 8,5/1 CR 037 ECU 017 CHT plus Resistor BUT 043 MPS which I thought can be calibrated like 037 MPS. Is that not possible? Do I need to look out for a 037 or 049 MPS since the 043 can not be adjusted to that settings? Thanks, Frank It's easier to adjust a MPS using a 044 ECU out of a 74 than a 037 ECU. You have to have enough room (richness) at the WOT and using a 037 barely has enough. Plus you must have the rare 017 CHT with resistor for the idle to work at all with the 037 ECU. AArgh, I have two working 037 ECU's and always thought the problem is only the 017 CHT which is NLA. I have two NOS units of that... That means I need to look for a 044 ECU now otherwise my engine will end up idling to rich and run to lean at WOT? Thanks, Frank |
| Bleyseng |
Feb 17 2016, 02:45 AM
As long as: You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! I'm confused now. I'm just about to put my new engine together. 2056 cc 9590 cam 8,5/1 CR 037 ECU 017 CHT plus Resistor BUT 043 MPS which I thought can be calibrated like 037 MPS. Is that not possible? Do I need to look out for a 037 or 049 MPS since the 043 can not be adjusted to that settings? Thanks, Frank It's easier to adjust a MPS using a 044 ECU out of a 74 than a 037 ECU. You have to have enough room (richness) at the WOT and using a 037 barely has enough. Plus you must have the rare 017 CHT with resistor for the idle to work at all with the 037 ECU. AArgh, I have two working 037 ECU's and always thought the problem is only the 017 CHT which is NLA. I have two NOS units of that... That means I need to look for a 044 ECU now otherwise my engine will end up idling to rich and run to lean at WOT? Thanks, Frank The 037 ECU was setup for the 72-73 1.7L and Porsche had to make it work for the 73 2.0L as Bosch didn't have enough time to make a 2.0L unit. Hence the 037 MPS and 017 Cht with resistor. Using a 037 ECU is just a lot harder to make work with a 2056cc engine with a Raby cam as it needs a richer mix. So starting with a ECU that already needs a way richer mix means you have little adjustment left on the MPS. Way easier to use a 044 ECU......and it runs and idles better believe me. |
| Frank S |
Feb 17 2016, 09:53 AM
As long as: You have a stock grind cam with your 2056 the 044 ECU is fine. The 049 can be adjusted to run with the 2056 no problem as it can be reset to the 043 specs. The 007 can be adjusted too to run with the 2056 IIRC If you have a nonstock cam like a Raby 9550 or a Web73 only the 049 can be adjusted to run with the 2056 because it doesn't have the inner cast stop ring in the cover which limits the amount of travel/adjustability for WOT Make sure you have the correct 012 CHT! I'm confused now. I'm just about to put my new engine together. 2056 cc 9590 cam 8,5/1 CR 037 ECU 017 CHT plus Resistor BUT 043 MPS which I thought can be calibrated like 037 MPS. Is that not possible? Do I need to look out for a 037 or 049 MPS since the 043 can not be adjusted to that settings? Thanks, Frank It's easier to adjust a MPS using a 044 ECU out of a 74 than a 037 ECU. You have to have enough room (richness) at the WOT and using a 037 barely has enough. Plus you must have the rare 017 CHT with resistor for the idle to work at all with the 037 ECU. AArgh, I have two working 037 ECU's and always thought the problem is only the 017 CHT which is NLA. I have two NOS units of that... That means I need to look for a 044 ECU now otherwise my engine will end up idling to rich and run to lean at WOT? Thanks, Frank The 037 ECU was setup for the 72-73 1.7L and Porsche had to make it work for the 73 2.0L as Bosch didn't have enough time to make a 2.0L unit. Hence the 037 MPS and 017 Cht with resistor. Using a 037 ECU is just a lot harder to make work with a 2056cc engine with a Raby cam as it needs a richer mix. So starting with a ECU that already needs a way richer mix means you have little adjustment left on the MPS. Way easier to use a 044 ECU......and it runs and idles better believe me. I believe you and I'm looking for a 044 ECU right now. Thank you so much for the information you share here to find that out myself would have taken years... Only thing I didn't understand 100% is: Could I use my 043 MPS and adjust it or must it be a 049 MPS? Thanks, Frank |
BeatNavy ECU/MPS Compatibility for 2056 Feb 17 2015, 05:26 PM
Jeff Bowlsby Hey Rob, I'm no DJet expert but I think there ... Feb 17 2015, 06:21 PM
BeatNavy Hi Jeff -- thanks for the reply. Now I see where ... Feb 17 2015, 06:35 PM
Jeff Bowlsby
The 049 can be adjusted to run with the 2056 no p... Feb 17 2015, 07:47 PM
914_teener
The 049 can be adjusted to run with the 2056 no ... Feb 17 2015, 09:35 PM
Bleyseng
The 049 can be adjusted to run with the 2056 no ... Feb 18 2015, 09:00 AM
Bleyseng
[quote name='Frank S' post='2303719' date='Feb 1... Feb 18 2016, 12:26 AM
worn
It's easier to adjust a MPS using a 044 ECU ... Feb 16 2016, 10:13 AM
BeatNavy Hi Geoff -- good info, thanks. Cam is stock. Sou... Feb 17 2015, 06:47 PM
worn
Hi Geoff -- good info, thanks. Cam is stock. So... Feb 19 2015, 06:25 PM
BeatNavy So Geoff, would you say my best bet is to either:
... Feb 18 2015, 09:20 AM
Bleyseng I have some spacers but you have to take apart the... Feb 18 2015, 05:52 PM
BeatNavy
I have some spacers but you have to take apart th... Feb 18 2015, 06:51 PM
Scarlet75 Geoff,
Do you have a picture of this spacer? Tha... Feb 19 2015, 10:52 AM
brant I'd love to buy a spacer...
or if these are al... Feb 19 2015, 10:56 AM
Phoenix914 :popcorn:
Rob, thanks for starting this thread.
... Feb 19 2015, 11:14 AM
BeatNavy
:popcorn:
Rob, thanks for starting this thread.... Feb 19 2015, 01:02 PM
Bleyseng Pic of inside a early cover showing the cast in st... Feb 19 2015, 12:06 PM
Scarlet75 Geoff,
Other then being cast this way, some MPS ... Feb 19 2015, 01:44 PM
Racer Chris I have a spacer in my spare parts collection. Thic... Feb 19 2015, 01:53 PM
BeatNavy
I have a spacer in my spare parts collection. Thi... Feb 19 2015, 02:45 PM
Racer Chris
Just to be clear though -- I think they... Feb 19 2015, 04:07 PM
brant
I have a spacer in my spare parts collection. Thi... Feb 19 2015, 02:49 PM
brant I'm struggling to visualize this...
but I want... Feb 19 2015, 02:03 PM
Jeff Bowlsby Chris is the Man for this MPS spacer ring, you alr... Feb 19 2015, 02:52 PM
914_teener There also was a rumor that the springs are differ... Feb 19 2015, 06:30 PM
Bleyseng Springs are differnet between the early and late o... Feb 19 2015, 06:44 PM
914_teener
Springs are differnet between the early and late ... Feb 19 2015, 07:45 PM
Bleyseng
[quote name='Bleyseng' post='2149020' date='Feb 1... Feb 19 2015, 08:14 PM
914_teener
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 19 2015, 09:52 PM
worn
[quote name='Bleyseng' post='2149020' date='Feb ... Feb 22 2015, 06:36 PM
barefoot There are 2 ways to increase fuel flow, everything... Feb 19 2015, 07:05 PM
Bob L.
There are 2 ways to increase fuel flow, everythin... Feb 19 2015, 07:33 PM
barefoot
There are 2 ways to increase fuel flow, everythi... Feb 19 2015, 07:48 PM
Bleyseng Pic of the 2.0L spacer ring Feb 22 2015, 05:35 PM
Racer Chris
Pic of many 2.0L spa... Nov 19 2015, 09:07 AM
914_teener
[quote name='Bleyseng' post='2150304' date='Feb 2... Nov 19 2015, 12:48 PM
Racer Chris
[quote name='Bleyseng' post='2150304' date='Feb ... Nov 19 2015, 03:28 PM
BeatNavy I put the 049 that came with my 2056 into my 1.7L ... Feb 22 2015, 06:54 PM
Bleyseng A 007 will work only if you have a late cover as t... Feb 22 2015, 08:34 PM
BeatNavy Chris - are you selling these now? So a x049 MPS ... Nov 19 2015, 09:36 AM
Racer Chris
I will be wit... Nov 19 2015, 09:40 AM
Olympic 1.7
I will be wi... Nov 19 2015, 07:46 PM
Jeff Bowlsby Anders published values are known to be lean. Nov 19 2015, 10:14 AM
BeatNavy
Re... Nov 19 2015, 10:50 AM
Jeff Bowlsby We're those values adjusted for your local eva... Nov 19 2015, 11:25 AM
BeatNavy Jeff - I did not adjust for sea level, but I'm... Nov 19 2015, 11:31 AM
pbanders I haven't got much to add, Bleyseng and Bowlsb... Nov 19 2015, 01:15 PM
396
I haven't got much to add, Bleyseng and Bowls... Nov 19 2015, 01:31 PM
Bleyseng
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 08:48 AM
worn
I haven't got much to add, Bleyseng and Bowls... Feb 16 2016, 10:09 AM
914_teener This has been a great thread for my 2056 D-jet bui... Nov 19 2015, 02:30 PM
BeatNavy
This has been a great thread for my 2056 D-jet bu... Nov 19 2015, 07:15 PM
saigon71 Great info...following this thread closely as I pl... Nov 19 2015, 07:41 PM
BeatNavy I spent a lot of time futzing with my MPS's (I... Feb 16 2016, 10:29 AM
Philip W. this might be slightly off topic but involves the ... Feb 17 2016, 08:06 AM
BeatNavy Those numbers sited on the Anders' site are ta... Feb 17 2016, 09:08 AM
Philip W.
Those numbers sited on the Anders' site are t... Feb 17 2016, 09:46 AM
Philip W. o.k. so as of today I found only one for sale out ... Feb 17 2016, 09:55 AM
worn
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:28 AM
BeatNavy
o.k. so as of today I found only one for sale out... Feb 17 2016, 10:30 AM
sean_v8_914 awesome thread. thank you Feb 17 2016, 11:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
