| mikesjunk |
Feb 15 2016, 07:15 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 29-November 15 From: goddard, KS Member No.: 19,423 Region Association: None |
So waiting on the ignition switch to return so this weekend I had all the parts to go through the shifter. Put in all new bushings front to back and it does feel better and I seem to find all the gears. 4th/5th feel pretty stiff. And when I was under the car it looked like it's rubbing the exhaust.
So didn't have any volunteers to come out and run the gears while I watched underneath so couldn't be in two places at once. I did mark the rods when I disconnected them. This is a tail shift so any tips, tricks, things to look for? Thanks again. |
| mikesjunk |
Feb 17 2016, 04:29 PM
Mark is there a special fat bladed screwdriver that works on these? Nothing in my box is a good fit so I might need to find something better prior to the vice grips and drill having to come out. (IMG:style_emoticons/default/smile.gif)
| mark04usa |
Feb 18 2016, 12:19 AM
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 363 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region
Mark is there a special fat bladed screwdriver that works on these? Nothing in my box is a good fit so I might need to find something better prior to the vice grips and drill having to come out. (IMG:style_emoticons/default/smile.gif) I use a Snap On SSD 6, 5/16" flat tip. You can get an 11mm wrench on the upper shank of it for really tough screws. It has a long handle, so no good in tight spots. HF stuff is OK sometimes, but I sure do recommend Snap On screw drivers and sockets and wrenches...your fasteners will thank you. |
mikesjunk Shifter rod rubs exhaust after bushings Feb 15 2016, 07:15 PM
Dave_Darling You say it's a "Frankenstein". In w... Feb 15 2016, 08:20 PM
mikesjunk Frankenstein in the nickname for this car/project ... Feb 16 2016, 04:55 PM
mepstein Finesse first. I have a lot of 1.7 exhaust and shi... Feb 16 2016, 05:00 PM
r_towle Could you post a bigger picture of where it rubs, ... Feb 16 2016, 05:14 PM
mark04usa Looks like the left heater supply pipe is not full... Feb 16 2016, 05:51 PM
mikesjunk Ok so got the wife out to run the gears and it... Feb 16 2016, 05:54 PM
mikesjunk Ok so as above this appears to be the heater suppl... Feb 16 2016, 07:39 PM
mark04usa Hey, those old German slot head screws work great ... Feb 16 2016, 08:32 PM
r_towle yup, it does look like the heater box is not mount... Feb 17 2016, 03:12 PM
Dave_Darling
Mark is there a special fat bladed screwdriver th... Feb 17 2016, 10:39 PM
r_towle Harbor freight impact screwdriver is a must have t... Feb 17 2016, 05:15 PM
mikesjunk Thanks I have one around the corner from work. Lo... Feb 17 2016, 05:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd May 2026 - 08:29 AM |
