> starter issue, how do I tell if it's going bad?
914 RZ-1
post Feb 15 2016, 03:39 PM
Porsche Padawan
My car wouldn't start the other day. Battery is good. The starter would not even turn over, but I could hear the fuel pump working. Radio also worked. I was able to push start it to get home. When I got home, I shut the engine off and then tried to start the car. The starter worked. Haven't tried it since, though.
1. How do I tell if the starter is going bad? It sounds ok, but maybe I'm not listening for the right kind of sounds.
2. I'll check all the connections and post my findings as well, but what should I check: terminals on starter, what else?
3. Someone told me to tap on the starter with a hammer. Where? What am I trying to do?
4. Is it better to rebuild or replace? How do I tell if a place is any good? Got a recommendation for a local place, but just based on price.
Thanks in advance!
Series9
post Feb 18 2016, 02:59 PM
Lesbians taste like chicken.
(IMG:style_emoticons/default/agree.gif) Do this first.
914 RZ-1   starter issue   Feb 15 2016, 03:39 PM
The Cabinetmaker   If you must hit it, don't hit the solenoid. Th...   Feb 15 2016, 03:58 PM
Mark Henry   Clean grounds and contacts first, then add the For...   Feb 15 2016, 03:59 PM
914 RZ-1   Clean grounds and contacts first, then add the Fo...   Feb 18 2016, 11:58 AM
Mark Henry   Clean grounds and contacts first, then add the F...   Feb 18 2016, 12:02 PM
914 RZ-1   [quote name='914 RZ-1' post='2304607' date='...   Feb 18 2016, 01:43 PM
r_towle   wiring at ignition switch gets old and tired, its ...   Feb 15 2016, 04:00 PM
Bob L.   Could also be the ignition switch itself, Electric...   Feb 15 2016, 04:07 PM
Rand   A common problem that causes this is a crack in th...   Feb 15 2016, 04:07 PM
Series9   A common problem that causes this is a crack in t...   Feb 15 2016, 04:15 PM
914 RZ-1   A common problem that causes this is a crack in ...   Feb 18 2016, 12:04 PM
Series9   Step 1: Unplug the solenoid and jumper the large ...   Feb 15 2016, 04:07 PM
914 RZ-1   Step 1: Unplug the solenoid and jumper the large...   Feb 18 2016, 12:01 PM
Rand   Great minds run in the same gutters.   Feb 15 2016, 04:31 PM
Series9   Great minds run in the same gutters. Accepted....   Feb 15 2016, 04:45 PM
Justinp71   From what I remember there are 4 common problems (...   Feb 15 2016, 05:34 PM
914 RZ-1   From what I remember there are 4 common problems ...   Feb 18 2016, 12:03 PM
914 RZ-1   From what I remember there are 4 common problems...   Feb 18 2016, 01:43 PM
Bartlett 914   To this I would add a bad connection under the pas...   Feb 18 2016, 03:39 PM
Jeffs9146   To this I would add a bad connection under the pa...   Feb 18 2016, 03:43 PM
Rand   Under the car at the starter. See photo. Rest a s...   Feb 18 2016, 02:07 PM
Series9   :agree: Do this first.   Feb 18 2016, 02:59 PM
Series9   There has been a ton of speculation. Less reading...   Feb 18 2016, 04:23 PM
ThePaintedMan   Joe is giving you the most logical troubleshooting...   Feb 18 2016, 04:26 PM
- Lo-Fi Version Time is now: 3rd October 2026 - 08:23 AM
