Installing dash face vinyl, 914 rubber late model |
80cap |
Feb 8 2016, 04:35 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
Do you need to drop the steering wheel to fit the metal backing plate onto to the dash?
I want to instal the vinyl to the backing plate then using double sided 3m tape attach the plate to the main dash. Also the kit doesn't include a plate for the glove box door. I assume it doesn't need it. Thanks Brian |
lsintampa |
Feb 22 2016, 09:43 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I just did mine and yes you need to "drop" the steering wheel. Removing all the light switches and the heater control is obviously mandatory.
BTW - when you have to deal with that heater control assembly, the best thing is to remove the two cables that connect to the left front air valve controller - just make sure you label them. Disconnect from the front hood - then pull them into the cabin. Then remove only the one cable inside (top level of the heater control assembly). That seemed to be the easiest way. Label all wires - I have one ground wire now that I'm not sure where it goes. If I run it directly to ground - my fresh air blower light is constant on - regardless of position of the blower motor switch. I think that it grounds to the assembly somewhere. Anyway back to the wheel situation. Best to lower the whole thing. Unbolt the 4 bolts that hold it up then you have to wiggle fit the face on. Worked for me that way. Good luck! Len Do you need to drop the steering wheel to fit the metal backing plate onto to the dash? I want to instal the vinyl to the backing plate then using double sided 3m tape attach the plate to the main dash. Also the kit doesn't include a plate for the glove box door. I assume it doesn't need it. Thanks Brian |
Lo-Fi Version | Time is now: 8th June 2024 - 10:57 PM |
