| puffinator |
Feb 23 2016, 01:22 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I have a 914/6 and I need some wiring help. The attached photo shows the engine compartment wiring harness (behind the engine) with a green wire that I do not know what it should attach to. I don’t have a wiring diagram. The photo is of the portion of the harness branching off from behind the engine to the alternator.
| puffinator |
Feb 24 2016, 10:50 AM
| gereed75 |
Feb 24 2016, 10:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
The bundle goes to the relay board, the starter, the alternator, oil pressure, and the battery. The green wire goes to this position on the relay plug. The previous owner had cut the wire. I do not have my wiring diagram handy but I am pretty sure that that is a wire supplied for trans temp sender on sporto models. From the relay board it goes to the gauge cluster and is very handy for adding pressure gauge input for combo gauges. I will not be able to verify until early March |
puffinator 914/6 Engine Harness wiring question Feb 23 2016, 01:22 PM
McMark Did you install the devil tape (electrical tape)? ... Feb 23 2016, 02:13 PM
aturboman There was originally a wire that activated the dec... Feb 23 2016, 06:29 PM
gandalf_025 The deceleration valve used 2 wires. A red and a... Feb 23 2016, 07:51 PM
mskala I don't have any green in that area. Can... Feb 23 2016, 09:45 PM
puffinator Where does the temperature sensor wiring go and wh... Feb 24 2016, 12:58 PM
gereed75
Where does the temperature sensor wiring go and w... Feb 24 2016, 02:55 PM
puffinator
Where does the temperature sensor wiring go and ... Feb 24 2016, 03:40 PM
gereed75
[quote name='gereed75' post='2307387' date='Feb 2... Feb 24 2016, 04:11 PM
puffinator What color wire is attached to your oil temperatur... Feb 24 2016, 04:57 PM
gereed75
What color wire is attached to your oil temperatu... Feb 24 2016, 06:06 PM
gereed75 [quote name='gereed75' date='Feb 24 20... Feb 24 2016, 06:57 PM
gms #11 is Oil Temp, should be green with black stripe Feb 26 2016, 09:39 AM
Festive_Zombie Question for you electrical gurus, I'm buildin... Mar 16 2016, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 03:53 AM |
