| puffinator |
Feb 23 2016, 01:22 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I have a 914/6 and I need some wiring help. The attached photo shows the engine compartment wiring harness (behind the engine) with a green wire that I do not know what it should attach to. I don’t have a wiring diagram. The photo is of the portion of the harness branching off from behind the engine to the alternator.
| puffinator |
Feb 24 2016, 04:57 PM
What color wire is attached to your oil temperature sensor and where does that wire go? To the harness behind the engine or elsewhere?
puffinator 914/6 Engine Harness wiring question Feb 23 2016, 01:22 PM
McMark Did you install the devil tape (electrical tape)? ... Feb 23 2016, 02:13 PM
aturboman There was originally a wire that activated the dec... Feb 23 2016, 06:29 PM
gandalf_025 The deceleration valve used 2 wires. A red and a... Feb 23 2016, 07:51 PM
mskala I don't have any green in that area. Can... Feb 23 2016, 09:45 PM
puffinator The bundle goes to the relay board, the starter, t... Feb 24 2016, 10:50 AM
gereed75
The bundle goes to the relay board, the starter, ... Feb 24 2016, 10:59 AM
puffinator Where does the temperature sensor wiring go and wh... Feb 24 2016, 12:58 PM
gereed75
Where does the temperature sensor wiring go and w... Feb 24 2016, 02:55 PM
puffinator
Where does the temperature sensor wiring go and ... Feb 24 2016, 03:40 PM
gereed75
[quote name='gereed75' post='2307387' date='Feb 2... Feb 24 2016, 04:11 PM
gereed75
What color wire is attached to your oil temperatu... Feb 24 2016, 06:06 PM
gereed75 [quote name='gereed75' date='Feb 24 20... Feb 24 2016, 06:57 PM
gms #11 is Oil Temp, should be green with black stripe Feb 26 2016, 09:39 AM
Festive_Zombie Question for you electrical gurus, I'm buildin... Mar 16 2016, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 03:53 AM |
