| puffinator |
Feb 23 2016, 01:22 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I have a 914/6 and I need some wiring help. The attached photo shows the engine compartment wiring harness (behind the engine) with a green wire that I do not know what it should attach to. I don’t have a wiring diagram. The photo is of the portion of the harness branching off from behind the engine to the alternator.
| puffinator |
Feb 24 2016, 04:57 PM
What color wire is attached to your oil temperature sensor and where does that wire go? To the harness behind the engine or elsewhere?
| gereed75 |
Feb 24 2016, 06:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
What color wire is attached to your oil temperature sensor and where does that wire go? To the harness behind the engine or elsewhere? The stock oil temp sensor is on the driver side front of the engine. I do not recall what color that wire is (green and black I think) or exactly how it gets there. there is a stock oil pressure light switch wire. Can't remember color but again that is in the back part of the harness. In that same run are the previously mentioned wires for the cold start and deceleration dashpot . None of these are solid green BTW - The sporto did have a unique harness very different from the stock six harness (easily recognized) so any solid green wire after the relay board would have to have been added/spiced into your harness |
puffinator 914/6 Engine Harness wiring question Feb 23 2016, 01:22 PM
McMark Did you install the devil tape (electrical tape)? ... Feb 23 2016, 02:13 PM
aturboman There was originally a wire that activated the dec... Feb 23 2016, 06:29 PM
gandalf_025 The deceleration valve used 2 wires. A red and a... Feb 23 2016, 07:51 PM
mskala I don't have any green in that area. Can... Feb 23 2016, 09:45 PM
puffinator The bundle goes to the relay board, the starter, t... Feb 24 2016, 10:50 AM
gereed75
The bundle goes to the relay board, the starter, ... Feb 24 2016, 10:59 AM
puffinator Where does the temperature sensor wiring go and wh... Feb 24 2016, 12:58 PM
gereed75
Where does the temperature sensor wiring go and w... Feb 24 2016, 02:55 PM
puffinator
Where does the temperature sensor wiring go and ... Feb 24 2016, 03:40 PM
gereed75
[quote name='gereed75' post='2307387' date='Feb 2... Feb 24 2016, 04:11 PM
gereed75 [quote name='gereed75' date='Feb 24 20... Feb 24 2016, 06:57 PM
gms #11 is Oil Temp, should be green with black stripe Feb 26 2016, 09:39 AM
Festive_Zombie Question for you electrical gurus, I'm buildin... Mar 16 2016, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 03:54 AM |
