Fixed my odometer |
Fixed my odometer |
PanelBilly |
Feb 25 2016, 09:29 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
While the speedometer worked fine, the odometer wasn't working at all. Pelican has a technical write up on how repair them. I jumped right in and tore it open. Taking the barrel of numbers apart wasn't all that hard, but getting them lined up again took me a fair number of attempts. I figured it was best to just line up all the zeros, but the first roller slipped. Guess I'm starting the car over with 2 miles on it. Its not far from the truth
timothy_nd28 |
Feb 25 2016, 10:55 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Looks like you did a good job getting things realigned which can be a super PITA sometimes. I typically remove the face dial and run masking tape across all the wheels. This makes life easier keeping the wheels together as you pull out the supporting shaft. In addition to what the Pelican write up says, I also put a dab of locktite inside the free wheeling gear.
Lo-Fi Version | Time is now: 8th June 2024 - 04:01 PM |
