Oil Leak Hell |
Oil Leak Hell |
orbit398 |
Feb 26 2016, 07:00 PM
Member Group: Members Posts: 139 Joined: 29-April 15 From: League city, Texas Member No.: 18,681 Region Association: Southwest Region |
I like to ideas on what the heck is going on.
Doing a 1974 914 restoration. Stripped completely down to just the chassis, painted etc..... Ran great prior to start but had an oil lead that dripped down from the oil pump pressure relief valve screw. Assume it was the oil radiator. While engine was out, I replaced seals that mate the oil radiator to motor, making sure new seals were siliconed in place so they could not move during re-installation. Welded a nut to the oil pressure relief valve screw so I could really tighten it good (with new seal). Thought I fixed the oil leak. Installed engine, hooked up, started up. Still leaks oil staight down to Oil Pressure Relief Valve. Assume it can only be the stupid oil radiator again. What else could it be? Leaks good when engine running. Any ideas? thanks |
TheCabinetmaker |
Feb 27 2016, 03:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Stu, it's not all that easy. One of the jobs I dread. One of the console bolts cannot be removed without pulling the oil cooler forward.
Orbit, the oil cooler seals should only be coated with oil. Dried silicone will act as a deformity in the seal and it will leak. Others here will agree when I say "NO" silicone. The late Capn would not be so nice about it. |
sfrenck |
Feb 27 2016, 03:18 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Stu, it's not all that easy. One of the jobs I dread. One of the console bolts cannot be removed without pulling the oil cooler forward.... (IMG:style_emoticons/default/agree.gif) Just tried last week... couldn't get the darn top bolt off |
stugray |
Feb 27 2016, 11:01 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Stu, it's not all that easy. One of the jobs I dread. One of the console bolts cannot be removed without pulling the oil cooler forward.... (IMG:style_emoticons/default/agree.gif) Just tried last week... couldn't get the darn top bolt off You are probably right. Just a couple of weeks ago I removed the oil cooler with the engine in the car and put it all back together but with a blockoff plate at the oil cooler. So I remember putting the filter bracket back on was easy, but thats probably because the blockoff plate is not in the way. |
Lo-Fi Version | Time is now: 15th June 2024 - 11:41 AM |
