Weather Strip channel, Restoration Help |
lcjo73914 |
Mar 3 2016, 04:13 PM
Member Group: Members Posts: 56 Joined: 9-October 15 From: stockton - Ca Member No.: 19,250 Region Association: Northern California |
Please, any help on restoring the front trunk weather strip channel.
Any thread? Thank you Very much |
mgphoto |
Mar 6 2016, 03:44 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The tool to use to remove the rust is the Wurth DBS 3600. This tool is VERY effective with different size wire wheels and materials, sorry don't have a photo of it, look it up.
Remove all rust, cut through to wheel well, if need be. Mig welder, run some beads, grind flat. And repair the corners. Weld in and grind flat. Large sections, under cowl and front fascia, headlight buckets badly rotted would be easier to replace. Good luck Mike |
Lo-Fi Version | Time is now: 10th June 2024 - 06:02 AM |
