big progress recently,, filled the hole in the engine space with the right motor? |
porschetub |
Mar 8 2016, 01:50 AM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
LowBridge |
Mar 8 2016, 06:14 AM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
congrats on the progress... summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif)
Series9 |
Mar 8 2016, 12:49 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
.. summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif) Winter is just around the corner for him.... (IMG:style_emoticons/default/biggrin.gif) |
porschetub |
Mar 9 2016, 01:08 AM
.. summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif) Winter is just around the corner for him.... (IMG:style_emoticons/default/biggrin.gif) No issue Joe we have halfass winters here,I can wear overalls and not sweat my ass off under the car,good progress today as not helping builder on my ongoing house reno,car time rules (IMG:style_emoticons/default/smile.gif) . Got clutch cable (too long) sorted and working on throttle cable ,I was a cheap ass and used a 911 throttle arm modified and drilled the trans for the bell crank pivot,bellcrank (a 911 part) was cut/rewelded to suit full throttle movement. Fixed rubber lined stainless loops to hold cables up on engine case found to be handy and in the right place. Pics to follow and cheers for the comments all. |
porschetub |
Mar 9 2016, 10:57 PM
.. summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif) Winter is just around the corner for him.... (IMG:style_emoticons/default/biggrin.gif) No issue Joe we have halfass winters here,I can wear overalls and not sweat my ass off under the car,good progress today as not helping builder on my ongoing house reno,car time rules (IMG:style_emoticons/default/smile.gif) . Got clutch cable (too long) sorted and working on throttle cable ,I was a cheap ass and used a 911 throttle arm modified and drilled the trans for the bell crank pivot,bellcrank (a 911 part) was cut/rewelded to suit full throttle movement. Fixed rubber lined stainless loops to hold cables up on engine case found to be handy and in the right place. Pics to follow and cheers for the comments all. Clutch cable sorted by cutting 12mm of clevis end,sorta found my issue as the clutch lever shaft is pretty worn or is a larger for a reason ? certainly not "slotted out" due to wear,changes little as the cable was too long. Kind of went out of the square with the throttle setup ,drilled the trans case and fitted bellcrank pivot,then modded a 911 bellcrank to suit. Locking grubscrews to fit in to cable end and found a heater cable rubber bellows to keep some of the dirt out. Throttle pedal feels good but a little firm,can fine tune that. Its a pain lying on the sandy ground under the car but my nearest shed is full of ever diminishing building materials so will have space soon...I hope. |
Jeffs9146 |
Mar 10 2016, 01:11 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
.. summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif) Winter is just around the corner for him.... (IMG:style_emoticons/default/biggrin.gif) No issue Joe we have halfass winters here,I can wear overalls and not sweat my ass off under the car,good progress today as not helping builder on my ongoing house reno,car time rules (IMG:style_emoticons/default/smile.gif) . Got clutch cable (too long) sorted and working on throttle cable ,I was a cheap ass and used a 911 throttle arm modified and drilled the trans for the bell crank pivot,bellcrank (a 911 part) was cut/rewelded to suit full throttle movement. Fixed rubber lined stainless loops to hold cables up on engine case found to be handy and in the right place. Pics to follow and cheers for the comments all. Clutch cable sorted by cutting 12mm of clevis end,sorta found my issue as the clutch lever shaft is pretty worn or is a larger for a reason ? certainly not "slotted out" due to wear,changes little as the cable was too long. Kind of went out of the square with the throttle setup ,drilled the trans case and fitted bellcrank pivot,then modded a 911 bellcrank to suit. Locking grubscrews to fit in to cable end and found a heater cable rubber bellows to keep some of the dirt out. Throttle pedal feels good but a little firm,can fine tune that. Its a pain lying on the sandy ground under the car but my nearest shed is full of ever diminishing building materials so will have space soon...I hope. You might compare your bellcrank operation to mine. Notice that mine pulls from the top with the cable and the crank pivots down to pull the shaft. I don't get any stiffness or resistance. Attached image(s) |
porschetub |
Mar 11 2016, 03:13 AM
.. summer is just around the corner and it looks like you might be on the road in time (IMG:style_emoticons/default/MDB2.gif) Winter is just around the corner for him.... (IMG:style_emoticons/default/biggrin.gif) No issue Joe we have halfass winters here,I can wear overalls and not sweat my ass off under the car,good progress today as not helping builder on my ongoing house reno,car time rules (IMG:style_emoticons/default/smile.gif) . Got clutch cable (too long) sorted and working on throttle cable ,I was a cheap ass and used a 911 throttle arm modified and drilled the trans for the bell crank pivot,bellcrank (a 911 part) was cut/rewelded to suit full throttle movement. Fixed rubber lined stainless loops to hold cables up on engine case found to be handy and in the right place. Pics to follow and cheers for the comments all. Clutch cable sorted by cutting 12mm of clevis end,sorta found my issue as the clutch lever shaft is pretty worn or is a larger for a reason ? certainly not "slotted out" due to wear,changes little as the cable was too long. Kind of went out of the square with the throttle setup ,drilled the trans case and fitted bellcrank pivot,then modded a 911 bellcrank to suit. Locking grubscrews to fit in to cable end and found a heater cable rubber bellows to keep some of the dirt out. Throttle pedal feels good but a little firm,can fine tune that. Its a pain lying on the sandy ground under the car but my nearest shed is full of ever diminishing building materials so will have space soon...I hope. You might compare your bellcrank operation to mine. Notice that mine pulls from the top with the cable and the crank pivots down to pull the shaft. I don't get any stiffness or resistance. no its all good can move it with foot fine but did this yesterday with my hand,as I said fine tuning required,I did it my way cause couldn't justify the conversion kit which INMO is overpriced from 2 suppliers I looked @,perhaps that's the tightass engineer coming out in me (IMG:style_emoticons/default/lol-2.gif) . Got the bellcrank from Brad @914ltd and the 911 throttle rod off local auction site,total cost around $70. Welding the cable retainer on the back of the clutch cable roller bracket isn't my idea but is a good solution. I see you are running a bronze/brass roller cable any issues with metal to metal wear? cheers. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:28 PM |
