> Tail to Side Shift Conversion Rookie
Jameel
post Mar 12 2016, 08:25 AM
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right.
So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible.
I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread.
Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others.
Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane.
jcd914
post Mar 12 2016, 06:10 PM
QUOTE(Jameel @ Mar 12 2016, 06:25 AM) *
Use you mouse to grab the bottom right corner of the of the composition pane and drag down and out to make the pane larger.
The is also a "+" and a "-" button at the bottom left corner of the composition pane that will lengthen or shorten the pane.
Jim
Jameel   Tail to Side Shift Conversion Rookie   Mar 12 2016, 08:25 AM
Spoke   Dr Evil here has a DVD on how to rebuild the 901 t...   Mar 12 2016, 09:12 AM
The Cabinetmaker   As for the smilie thing, just use the fast reply b...   Mar 12 2016, 12:42 PM
396   A few days ago I decided to take a closer look at...   Mar 12 2016, 12:44 PM
jcd914   Sort of off topic too, but is there any way to g...   Mar 12 2016, 06:10 PM
stugray   One trick: You have to remove the engine bar to p...   Mar 12 2016, 07:06 PM
Jameel   Thanks everybody. I don't have any doubts that...   Mar 12 2016, 08:16 PM
Jameel   Took the day off to work on this. I spent the last...   Mar 17 2016, 07:56 PM
Jameel   Next I loosened the connection between the two shi...   Mar 17 2016, 08:08 PM
Jameel   Next I began removing the engine support bar to re...   Mar 17 2016, 08:26 PM
SKL1   May I recommend while you're going to that tro...   Mar 17 2016, 09:46 PM
Jameel   May I recommend while you're going to that tr...   Mar 17 2016, 10:01 PM
ndfrigi   You might want to just get a set of side shift par...   Mar 17 2016, 10:05 PM
Jameel   You might want to just get a set of side shift pa...   Mar 18 2016, 07:53 PM
rhodyguy   The fact that most if not all of the bushings are ...   Mar 18 2016, 08:38 AM
Jameel   Managed to sneak in a couple hours on the 914 afte...   Mar 18 2016, 08:19 PM
eyesright   Good work and nice write up. We are waiting with.....   Mar 19 2016, 04:41 AM
Jameel   Good work and nice write up. We are waiting with....   Mar 19 2016, 07:06 PM
Jameel   So this is the first entire day I've been able...   Mar 19 2016, 08:58 PM
SKL1   Wonder why you had to cut out that access hole in ...   Mar 19 2016, 10:16 PM
brant   Wonder why you had to cut out that access hole in...   May 21 2016, 12:11 AM
stugray   Wonder why you had to cut out that access hole i...   May 21 2016, 11:43 AM
zambezi   watch out on the reverse light switch. There shou...   Mar 19 2016, 10:18 PM
Jameel   watch out on the reverse light switch. There sho...   Mar 20 2016, 11:38 AM
Dr Evil   Looking good! Brad is a great guy and will al...   Mar 20 2016, 10:55 AM
Jameel   Had an hour today to fiddle with this. First up, I...   Mar 21 2016, 09:36 PM
Jameel   Moving along....I removed the side cover plate whi...   Mar 26 2016, 08:44 AM
Dr Evil   Hard to tell in the video, there looks to be some ...   Mar 26 2016, 09:31 AM
Jameel   Thanks for the info. As for recognizing noise, I ...   Mar 26 2016, 03:03 PM
Jameel   Dropped my flywheel off this morning, got it back ...   Mar 29 2016, 09:46 PM
mepstein   I just resurfaced mine for my six conversion. For ...   Mar 29 2016, 09:57 PM
Dr Evil   Things to consider: 1) Was the flywheel finished t...   Mar 29 2016, 10:41 PM
Dr Evil   Specs   Mar 29 2016, 10:44 PM
Dave_Darling   One thing I spotted early on--one of the wires goi...   Mar 30 2016, 04:23 PM
Jameel   I just resurfaced mine for my six conversion. For...   Mar 30 2016, 07:24 PM
76-914   :bump:   Mar 31 2016, 08:09 AM
Jameel   While studying the good Dr.'s DVD I've bee...   Mar 31 2016, 06:22 PM
forrestkhaag   Amen on Tangerine's products RE: side shift co...   Mar 31 2016, 06:30 PM
stugray   The dog teeth in those pics look pretty good. One...   Mar 31 2016, 07:17 PM
Jameel   The dog teeth in those pics look pretty good. On...   Apr 6 2016, 08:30 AM
Phoenix-MN   [quote name='stugray' post='2323238' date='Mar 31...   Apr 6 2016, 09:02 AM
Jameel   My Panoramas only go back to '92. Any chance y...   Apr 6 2016, 01:31 PM
db9146   My Panoramas only go back to '92. Any chance ...   Apr 6 2016, 09:04 PM
Jameel   [quote name='Jameel' post='2326808' date='Apr 6 2...   Apr 8 2016, 02:02 PM
Dr Evil   Yer teeth are worn. Like saggy roofs. Look to the ...   Apr 6 2016, 09:29 PM
Jameel   Yer teeth are worn. Like saggy roofs. Look to the...   Apr 7 2016, 06:19 AM
oldie914   Your March 31st video shows visible end play on yo...   Apr 7 2016, 01:52 AM
oldie914   Here are some more pictures showing indicators of ...   Apr 7 2016, 03:27 AM
Jameel   Thanks for the tips oldie914. I'll look closer...   Apr 7 2016, 06:42 AM
Jameel   Got some deliveries past couple days. I have every...   Apr 8 2016, 08:28 PM
Jameel   Lots to report today. Here's my setup for taki...   Apr 9 2016, 05:58 PM
Jameel   Well, I guess I screwed up. Sort of half assed cle...   Apr 9 2016, 09:01 PM
Jameel   Putting my case back together I had to reuse the b...   Apr 12 2016, 08:07 PM
db9146   Here is the much better scan of the Pano article f...   Apr 15 2016, 11:33 AM
Dr Evil   Great job on this! Looking like you got it all...   Apr 18 2016, 08:22 PM
Jameel   Thank you Sir! I'm just waiting on some ne...   Apr 19 2016, 07:45 AM
Jameel   So I'm still waiting on a couple rubber boots ...   May 8 2016, 07:36 AM
Jameel   Made some good progress this week. Got the shifter...   May 14 2016, 08:07 AM
Jameel   Today I finished up the side shift conversion...   May 15 2016, 08:40 PM
gereed75   Really nice write up. Thanks   May 16 2016, 04:30 AM
Jameel   Hopefully someone in my shoes someday will find it...   May 17 2016, 07:49 AM
Porsche930dude   I just picked up a junk yard side shift trans toda...   May 20 2016, 09:39 PM
Jameel   I just picked up a junk yard side shift trans tod...   May 21 2016, 05:58 AM
Dave_Darling   I just picked up a junk yard side shift trans tod...   May 21 2016, 11:18 AM
Porsche930dude   I just picked up a junk yard side shift trans to...   Jun 9 2016, 09:05 PM
Cuda911   Excellent work, Jameel, and excellent write-up. Th...   May 20 2016, 11:54 PM
Jameel   Thanks! Great news! Two nights ago I got e...   May 21 2016, 05:47 AM
Jameel   Just a quick follow up. I got my brakes bled prope...   Jun 5 2016, 09:37 PM
gereed75   Nice work and really nice looking car(s). Feels gr...   Jun 6 2016, 06:26 AM
mbseto   I've been tearing around town in this little ...   Jun 6 2016, 07:59 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:54 AM
