> NGK DP8EA-9
era vulgaris
post Mar 14 2016, 05:55 AM
J is for Genius
So it came as a surprise that my car has 12mm plugs. I thought all 914's had 14mm? (IMG:style_emoticons/default/confused24.gif)
The PO was using NGK DP8EA-9. Looks like they have a pretty high heat rating at 8. The 14mm plugs most people seem to recommend, and that I used on my old 1.7 are the NGK BP6ES, which have a heat rating of 6.
Should I be looking for a similar rated plug for my current car? It's a 2270 with Mallory Unilite dizzy, MSD 6AL, and MSD Blaster 2 coil. Is there a better plug for my setup than the DP8EA-9?
era vulgaris
post Mar 14 2016, 10:17 AM
J is for Genius
Ok thanks, good to know!
No issue, just curious if they were optimal for my setup.
Mark Henry
post Mar 14 2016, 12:47 PM
that's what I do!
QUOTE(era vulgaris @ Mar 14 2016, 12:17 PM) *
Is this on your 2270cc?
Look at your plugs electrode, is it a nice tan/brown colour?
Then you are golden, stop overthinking things.
If the electrode is bright white then you have a big problem.
All dirty black, problem but not as bad.
...and both of the above could be timing and/or jetting and still not be plug related.
- Lo-Fi Version Time is now: 11th July 2025 - 06:44 PM
