r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So my daughters 1999 vw cabrio had the wipers stop working while driving back to school.
So, the car is not here, it's 3 hours away, with an EE student. She has a meter, not much else. There is a trusted vw shop up the street if it come to that. She checked the fuse, it is fine. I need to get her to test the relay and I have no clue how to do that without it in my hand. Does anyone know how to test a multi speed wiper relay? Also, if we can determine with a jumper in place of the relay, if the motor works or if the motor is bad, that would be an even simpler way to test the relay.....by proving the motor works. Rich |
r_towle |
Specific question for you electrical guys.
How do you bench test this relay? Attached image(s) ![]() |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,707 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Specific question for you electrical guys. How do you bench test this relay? Not real easy ,are you sure the wiper switch on the column hasn't crapped itself,thinking 1999 convertible is a mk3 golf platform right?,the switches on these do die. A jumper cable will be #30 to 86 or 87 sorry but the memory isn't what it was (IMG:style_emoticons/default/sad.gif) . Buy a new relay it should be numbered ,not expensive but may be specific to this model golf choose carefully,best thing to try first,cheers. |
Lo-Fi Version | Time is now: 16th June 2024 - 06:26 PM |
