> Urethane rubber seal on windshield installation
shoguneagle
post Mar 25 2016, 12:04 AM
shoguneagle
Ok, I have had my windshield installed with urethane sealant and rubber seal. Prior to this installation, I had another 914 sealed the same way. I do not want to get into whether to use original windshield installation methods, etc.
The problem relates to the lower corners do not want to lay down and flatten out. I have used heat lamp, tape, etc over extended periods of time. I have even used gorilla tape to hold the rubber seal down. It just does not want to stay flat. The problem relates to how can solve this problem and keep the rain/water out of the windshield area. I have come to the point of using two part urethane seal/glue and tape/weight the corners down. When considering methods such as this the job usually gets sloppy and does not work well.
I need suggestions on how I can get the rubber corners to lay flat and stay flat. Any suggestions or knowledge is greatly appreciated.
Thanks,
Steve (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/bye1.gif)
SA-914
post Mar 25 2016, 05:16 AM
I used a dab of black weatherstrip glue then set a small bean bag over the corner and strapped it down for week. The bean bag will conform to the body pushing the rubber down. It finally stayed down. Only had a issue on driver side.
- Lo-Fi Version Time is now: 9th July 2025 - 04:36 PM
