> 914World Classifieds Rules
> Euro Turn Signal Conversion $280.00 plus shipping
Martin Baker
post May 20 2013, 08:44 PM
I just heard I sold my cars!
To make it a little more clear, current prices for my conversions.
Ready to Install, complete pair of signal housings. $280.00 plus shipping.
Martin Baker
post Mar 26 2016, 10:07 AM
Again, thanks for the kudos on my conversions, compliments are always good for the soul, in this thankless world! On to the fun stuff!
Tires are the Toyo R888, P235/50/15. After finding out the many modern type DOT R tires are on the approved list for SVRA and CSRG, I took off the Hooiser Street TD I had been running, FUN, but not fast, compared to the DOT R rubber. I wasn't sure these tires would fit the back of my car, and I had always stuck with a 225 size in the width spectrum. It was a close fit, without rubbing. I, more or less have rolled the dice here, and when I picked them up after mount/balance, I was sure I had come up short on my gamble. I was already trying to work the logistics of a second set of R888 rear tires in the 225 width, which they also make. They are a little shorter. I installed and did a suspension compression check with close fit, but no rubbing in the normal travel area. Drove it around the block, it all seems to work now, but I will know more after the first practice next Saturday! I have a feeling I will need to adjust the front bar setting, as I am sure these tires will bring some push into the mix. The first session will be info overload, with the multiple changes over the Winter, tires, transmission, rear brakes(PMB Alloy 914/6 GT Rears, from a spaced 4 cylinder caliper), IDT3C Webers (the economy Weber, 911T,914/6) converted to IDAs (the performance Weber, 911S), by Paul Abbot (Performance Oriented) up in Chico (who I believe, will be attending), with a more race type set up. If you have questions about your Webers, Paul is the guy. He lives Weber carbs. Too many changes at once really, but, you know how that goes! All for a few seconds on a piece of paper, and a little bragging from a good friend and his Alfa GTV, which rubbed me the wrong way! Action must be taken!
One thing for sure is the car now looks like a drag car from behind. Those tires are huge!
Martin Baker   Euro Turn Signal Conversion $280.00 plus shipping   May 20 2013, 08:44 PM
Martin Baker   Installed....   May 20 2013, 08:46 PM
Martin Baker   More, I love 914 types.   May 20 2013, 08:49 PM
Martin Baker   ......   May 20 2013, 08:54 PM
Martin Baker   This shot gives a good idea of how much light a 7....   May 20 2013, 08:59 PM
914Sixer   Pretty Cool !!!!!   May 20 2013, 09:07 PM
mharmon   I'll take 1 complete set and 1 DIY if you have...   May 20 2013, 10:44 PM
Martin Baker   Mike Thank You! I can make the refractors in a...   May 20 2013, 11:03 PM
JmuRiz   I'll send you a PM, these'll go great with...   May 21 2013, 07:58 AM
horizontally-opposed   Hey Martin, I'd like to do this when I get th...   May 21 2013, 10:52 AM
Harpo   Very interesting. Does this require a special len...   May 21 2013, 04:34 PM
Martin Baker   When I started making these, I would make a set fo...   May 21 2013, 07:27 PM
Martin Baker   Thank you to both of the buyers for these two sets...   May 21 2013, 07:40 PM
Harpo   I'm interested if any are still available Tha...   May 22 2013, 09:53 AM
Martin Baker   Begin another pair tonight. I will make one set of...   May 22 2013, 10:23 AM
jim_hoyland   PM sent   May 22 2013, 01:25 PM
rgalla9146   PM sent Hello What is the cost if I send you m...   May 22 2013, 08:44 PM
Martin Baker   [quote name='jim_hoyland' post='1867871' date='Ma...   May 22 2013, 09:13 PM
B2524   interested in a set. can you PM me your phone # so...   May 23 2013, 07:49 AM
Martin Baker   interested in a set. can you PM me your phone # s...   May 23 2013, 09:34 AM
L-Jet914   Martin Baker, I ended up doing something like what...   May 26 2013, 12:22 AM
Martin Baker   Looks good, I wanted to stay away from aluminum, a...   May 26 2013, 08:05 AM
L-Jet914   I only used the aluminum for the shield itself. I...   May 27 2013, 01:14 AM
Martin Baker   I will have another set of these complete tomorrow...   Dec 20 2015, 07:30 PM
hcdmueller   Pm sent.   Dec 20 2015, 10:07 PM
Martin Baker   Thanks. Replied, and awaiting your usable housing.   Dec 21 2015, 03:35 PM
Martin Baker   Here they are, ready to be shipped. New bulbs incl...   Dec 21 2015, 06:52 PM
mharmon   Martin's set is top notch and he's a great...   Dec 21 2015, 08:19 PM
mtn flyr   Pm coming   Dec 21 2015, 08:23 PM
Martin Baker   OK first, THANKS Mike! I will take a pat on th...   Dec 21 2015, 08:37 PM
Mblizzard   If you happen to do another set I would like to ha...   Dec 30 2015, 07:37 PM
Martin Baker   If you happen to do another set I would like to h...   Dec 31 2015, 12:05 AM
Mblizzard   If you happen to do another set I would like to ...   Dec 31 2015, 11:53 AM
scrz914   Martin, if/when you have a DIY kit, I would like t...   Jan 1 2016, 11:54 PM
Martin Baker   I have never seen red in my life, could be custom,...   Jan 2 2016, 11:36 AM
scrz914   Responded. Thanks.   Jan 2 2016, 12:06 PM
Martin Baker   Here is the photos for the DIY folks, thanks to th...   Jan 5 2016, 02:05 PM
Martin Baker   After the refractor is set in place, with the bulb...   Jan 5 2016, 02:13 PM
Martin Baker   So now, your refractor is set, tight, wire is plac...   Jan 5 2016, 02:17 PM
Martin Baker   So now this is the important stuff. You will cut t...   Jan 5 2016, 02:20 PM
Martin Baker   With the 57 terminal cut as shown, and your wire c...   Jan 5 2016, 02:31 PM
Martin Baker   Next solder up your connection. The direction you ...   Jan 5 2016, 02:38 PM
Martin Baker   I test every unit I build here before I send them ...   Jan 5 2016, 02:50 PM
scrz914   I honestly didn't know it was that complex to ...   Jan 5 2016, 07:46 PM
Martin Baker   I have multiple cores now, (Thanks Al) and will ha...   Jan 24 2016, 09:04 AM
Jett   Looking for a set, the PO had installed euro lense...   Jan 24 2016, 10:44 AM
Garland   DIY worked out great, thanks for the details, and ...   Jan 25 2016, 01:13 PM
75-914   PM sent   Jan 26 2016, 12:31 AM
raynekat   Martin, is this a service you plan to offer for aw...   Jan 26 2016, 05:00 AM
Martin Baker   Martin, is this a service you plan to offer for a...   Jan 26 2016, 09:15 AM
Martin Baker   Been busy this week! Thanks to everyone! S...   Feb 5 2016, 02:29 PM
Martin Baker   Here is what I will ship today, I am caught up...   Feb 5 2016, 02:31 PM
jkb944t   They look great! I hope the two loose reflect...   Feb 5 2016, 03:08 PM
Martin Baker   They look great! I hope the two loose reflec...   Feb 5 2016, 03:10 PM
porschetub   They look great! I hope the two loose refle...   Feb 5 2016, 07:33 PM
Jett   They look amazing, can't wait to bolt on our s...   Feb 5 2016, 08:53 PM
brand mountain   ordered a set of these from martin and he turned t...   Mar 25 2016, 07:19 PM
Martin Baker   Thank you for the kind words. I really appreciate ...   Mar 25 2016, 07:46 PM
rgalla9146   Great job on the lamps Martin ! What is the...   Mar 26 2016, 06:12 AM
Martin Baker   Again, thanks for the kudos on my conversions, com...   Mar 26 2016, 10:07 AM
forrestkhaag   Martin: What is your turn around time for a set of...   Mar 26 2016, 04:51 PM
Martin Baker   Martin: What is your turn around time for a set o...   Mar 26 2016, 06:55 PM
johnpierre   To make it a little more clear, current prices fo...   Mar 27 2016, 11:42 AM
Martin Baker   Thanks a lot for the inquiry. I do not provide the...   Mar 27 2016, 01:40 PM
gulf908   Martin, I would like to order a pair of these eur...   Mar 28 2016, 12:05 AM
raynekat   Martin: I am back in town now and would like to se...   Apr 21 2016, 08:32 AM
Martin Baker   Back in California! PM replied to and I will g...   Apr 24 2016, 11:44 AM
flmont   Martin,..could you wire the buckets up,...and make...   Apr 26 2016, 08:56 PM
Martin Baker   Yes of course, with the miracle of electrical wiri...   Apr 26 2016, 09:26 PM
Martin Baker   Little update for folks expecting, here's wher...   May 15 2016, 11:11 AM
raynekat   Little update for folks expecting, here's whe...   May 15 2016, 11:55 AM
Martin Baker   Thanks allot Doug! I appreciate it. His set wa...   May 15 2016, 12:08 PM
eric914   Martin, are DIY kits still available?   Mar 21 2017, 09:15 PM
rgalla9146   Hi Martin Me too, Are DIY kits still available ...   Mar 22 2017, 10:20 AM
Martin Baker   Hey folks, have not looked at this stuff for a whi...   Mar 23 2017, 10:02 AM
raynekat   Martin....you need to buy this. For $250, yo...   Mar 23 2017, 07:54 PM
Martin Baker   OK, so I have one set of sockets in my box of sign...   Mar 24 2017, 09:54 AM
Amenson   I would like to order a DIY kit. PM sent. Thanks...   May 21 2017, 09:22 PM
amfab   Semi-Hijack, Who owns the orange car on page one ...   May 22 2017, 10:21 AM
Martin Baker   Semi-Hijack, Who owns the orange car on page one...   Aug 16 2018, 10:35 PM
horizontally-opposed   Semi-Hijack, Who owns the orange car on page on...   Aug 17 2018, 01:10 AM
deemsriddle   I have my housings out and would like to have the ...   May 22 2017, 02:40 PM
Philip W.   beautiful car! - also would like a DIY kit f...   Aug 17 2018, 06:30 AM
Martin Baker   beautiful car! - also would like a DIY kit ...   Aug 17 2018, 11:04 AM
Philip W.   beautiful car! - also would like a DIY kit...   Aug 18 2018, 10:00 PM
Martin Baker   Fan of your fine example as well Pete. Took this a...   Aug 17 2018, 08:22 AM
horizontally-opposed   Fan of your fine example as well Pete. Took this ...   Aug 19 2018, 08:16 PM
Dominic   Martin, Are you coming out to Rennsport this year?...   Aug 17 2018, 08:34 AM
Martin Baker   Martin, Are you coming out to Rennsport this year...   Aug 17 2018, 11:12 AM
Martin Baker   I have had a couple PMs about these recently. I ha...   May 20 2020, 12:46 PM
porschetub   Bought the base kit from Martin,top notch and fitt...   May 20 2020, 02:30 PM
double-a   count me in for a pair of the inserts! thx   May 21 2020, 10:27 AM
PASHN8   Hi guys, Does anyone know if Martin is still arou...   Sep 21 2020, 08:45 PM
914andy   I would be up for a couple of kits myself. Guess w...   Sep 22 2020, 06:59 PM
mb911   I use to hear from Martin quite a bit.. I have not...   Sep 23 2020, 06:18 AM
danimal16   I have a project going and am very interested in a...   Jan 13 2021, 01:11 PM
Martin Baker   So I have not been on here in a few years...and I ...   Nov 11 2022, 02:38 PM
Martin Baker   So. looks like I had some fake PMs about buying si...   Nov 29 2022, 11:11 AM
racer914   So. looks like I had some fake PMs about buying s...   Nov 29 2022, 03:23 PM
beech4rd   PM sent. I'd like a pair Chris   Nov 29 2022, 06:06 PM
- Lo-Fi Version Time is now: 1st November 2026 - 11:15 AM
