Removing the Engine .. tips |
Beakster |
Mar 27 2016, 10:02 PM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
I have tried to find some info on removing the engine .. Dose any links or findings on youtube showing proper way of doing this task.. thanks guys
0396 |
Mar 28 2016, 11:45 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I'm going to add a few common sense ( some folks don't have any ).
- make sure you utilize a well made jack stands.....having the car fall on you will not make your day - loosen the lug bolts before you jack up the car...Otherwise you will need another person to press the brakes while its up Again, common sense on safety goes a long way. |
TheCabinetmaker |
Mar 28 2016, 04:14 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm going to add a few common sense ( some folks don't have any ). - make sure you utilize a well made jack stands.....having the car fall on you will not make your day - loosen the lug bolts before you jack up the car...Otherwise you will need another person to press the brakes while its up Again, common sense on safety goes a long way. I have never removed a wheel to remove the engine. |
Lo-Fi Version | Time is now: 11th June 2024 - 02:31 AM |
