> Tail to Side Shift Conversion Rookie
Jameel
post Mar 12 2016, 08:25 AM
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right.
So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible.
I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread.
Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others.
Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane.
Jameel
post Mar 30 2016, 07:24 PM
QUOTE(mepstein @ Mar 29 2016, 07:57 PM) *
I just resurfaced mine for my six conversion. For $40 bucks there's no reason not to. Also replaced the bearing. It's just a couple dollars.
I didn't get off quite so cheap. Mine was $73. But I ain't complaining!
QUOTE(Dr Evil @ Mar 29 2016, 08:41 PM) *
Things to consider:
1) Was the flywheel finished to within spec?
***Yes. I got the print from one of your old threads. And confirmed with Brad M. before heading to the shop.
2) You may need to grind down, ever so specifically, the tops of the new flywheel bolts as the clutch disk will sit closer to the crank and will often hit the bolt heads after an aggressive resurface such as what looks like you needed.
***They took off 0.023". And I still got groove. I was planning on grinding off .023"
3) You will need to put another washer under the pivot ball. Use teflon tape as the threads with two washers will seep oil pretty easily.
***Ok, will do.
QUOTE(Dave_Darling @ Mar 30 2016, 02:23 PM) *
One thing I spotted early on--one of the wires going to the interior light is always "hot". So either disconnect the battery or tape up the black wire so it doesn't short to ground.
--DD
I disconnected the batt. But I'll remember that!
Jameel   Tail to Side Shift Conversion Rookie   Mar 12 2016, 08:25 AM
Spoke   Dr Evil here has a DVD on how to rebuild the 901 t...   Mar 12 2016, 09:12 AM
The Cabinetmaker   As for the smilie thing, just use the fast reply b...   Mar 12 2016, 12:42 PM
396   A few days ago I decided to take a closer look at...   Mar 12 2016, 12:44 PM
jcd914   Sort of off topic too, but is there any way to g...   Mar 12 2016, 06:10 PM
stugray   One trick: You have to remove the engine bar to p...   Mar 12 2016, 07:06 PM
Jameel   Thanks everybody. I don't have any doubts that...   Mar 12 2016, 08:16 PM
Jameel   Took the day off to work on this. I spent the last...   Mar 17 2016, 07:56 PM
Jameel   Next I loosened the connection between the two shi...   Mar 17 2016, 08:08 PM
Jameel   Next I began removing the engine support bar to re...   Mar 17 2016, 08:26 PM
SKL1   May I recommend while you're going to that tro...   Mar 17 2016, 09:46 PM
Jameel   May I recommend while you're going to that tr...   Mar 17 2016, 10:01 PM
ndfrigi   You might want to just get a set of side shift par...   Mar 17 2016, 10:05 PM
Jameel   You might want to just get a set of side shift pa...   Mar 18 2016, 07:53 PM
rhodyguy   The fact that most if not all of the bushings are ...   Mar 18 2016, 08:38 AM
Jameel   Managed to sneak in a couple hours on the 914 afte...   Mar 18 2016, 08:19 PM
eyesright   Good work and nice write up. We are waiting with.....   Mar 19 2016, 04:41 AM
Jameel   Good work and nice write up. We are waiting with....   Mar 19 2016, 07:06 PM
Jameel   So this is the first entire day I've been able...   Mar 19 2016, 08:58 PM
SKL1   Wonder why you had to cut out that access hole in ...   Mar 19 2016, 10:16 PM
brant   Wonder why you had to cut out that access hole in...   May 21 2016, 12:11 AM
stugray   Wonder why you had to cut out that access hole i...   May 21 2016, 11:43 AM
zambezi   watch out on the reverse light switch. There shou...   Mar 19 2016, 10:18 PM
Jameel   watch out on the reverse light switch. There sho...   Mar 20 2016, 11:38 AM
Dr Evil   Looking good! Brad is a great guy and will al...   Mar 20 2016, 10:55 AM
Jameel   Had an hour today to fiddle with this. First up, I...   Mar 21 2016, 09:36 PM
Jameel   Moving along....I removed the side cover plate whi...   Mar 26 2016, 08:44 AM
Dr Evil   Hard to tell in the video, there looks to be some ...   Mar 26 2016, 09:31 AM
Jameel   Thanks for the info. As for recognizing noise, I ...   Mar 26 2016, 03:03 PM
Jameel   Dropped my flywheel off this morning, got it back ...   Mar 29 2016, 09:46 PM
mepstein   I just resurfaced mine for my six conversion. For ...   Mar 29 2016, 09:57 PM
Dr Evil   Things to consider: 1) Was the flywheel finished t...   Mar 29 2016, 10:41 PM
Dr Evil   Specs   Mar 29 2016, 10:44 PM
Dave_Darling   One thing I spotted early on--one of the wires goi...   Mar 30 2016, 04:23 PM
Jameel   I just resurfaced mine for my six conversion. For...   Mar 30 2016, 07:24 PM
76-914   :bump:   Mar 31 2016, 08:09 AM
Jameel   While studying the good Dr.'s DVD I've bee...   Mar 31 2016, 06:22 PM
forrestkhaag   Amen on Tangerine's products RE: side shift co...   Mar 31 2016, 06:30 PM
stugray   The dog teeth in those pics look pretty good. One...   Mar 31 2016, 07:17 PM
Jameel   The dog teeth in those pics look pretty good. On...   Apr 6 2016, 08:30 AM
Phoenix-MN   [quote name='stugray' post='2323238' date='Mar 31...   Apr 6 2016, 09:02 AM
Jameel   My Panoramas only go back to '92. Any chance y...   Apr 6 2016, 01:31 PM
db9146   My Panoramas only go back to '92. Any chance ...   Apr 6 2016, 09:04 PM
Jameel   [quote name='Jameel' post='2326808' date='Apr 6 2...   Apr 8 2016, 02:02 PM
Dr Evil   Yer teeth are worn. Like saggy roofs. Look to the ...   Apr 6 2016, 09:29 PM
Jameel   Yer teeth are worn. Like saggy roofs. Look to the...   Apr 7 2016, 06:19 AM
oldie914   Your March 31st video shows visible end play on yo...   Apr 7 2016, 01:52 AM
oldie914   Here are some more pictures showing indicators of ...   Apr 7 2016, 03:27 AM
Jameel   Thanks for the tips oldie914. I'll look closer...   Apr 7 2016, 06:42 AM
Jameel   Got some deliveries past couple days. I have every...   Apr 8 2016, 08:28 PM
Jameel   Lots to report today. Here's my setup for taki...   Apr 9 2016, 05:58 PM
Jameel   Well, I guess I screwed up. Sort of half assed cle...   Apr 9 2016, 09:01 PM
Jameel   Putting my case back together I had to reuse the b...   Apr 12 2016, 08:07 PM
db9146   Here is the much better scan of the Pano article f...   Apr 15 2016, 11:33 AM
Dr Evil   Great job on this! Looking like you got it all...   Apr 18 2016, 08:22 PM
Jameel   Thank you Sir! I'm just waiting on some ne...   Apr 19 2016, 07:45 AM
Jameel   So I'm still waiting on a couple rubber boots ...   May 8 2016, 07:36 AM
Jameel   Made some good progress this week. Got the shifter...   May 14 2016, 08:07 AM
Jameel   Today I finished up the side shift conversion...   May 15 2016, 08:40 PM
gereed75   Really nice write up. Thanks   May 16 2016, 04:30 AM
Jameel   Hopefully someone in my shoes someday will find it...   May 17 2016, 07:49 AM
Porsche930dude   I just picked up a junk yard side shift trans toda...   May 20 2016, 09:39 PM
Jameel   I just picked up a junk yard side shift trans tod...   May 21 2016, 05:58 AM
Dave_Darling   I just picked up a junk yard side shift trans tod...   May 21 2016, 11:18 AM
Porsche930dude   I just picked up a junk yard side shift trans to...   Jun 9 2016, 09:05 PM
Cuda911   Excellent work, Jameel, and excellent write-up. Th...   May 20 2016, 11:54 PM
Jameel   Thanks! Great news! Two nights ago I got e...   May 21 2016, 05:47 AM
Jameel   Just a quick follow up. I got my brakes bled prope...   Jun 5 2016, 09:37 PM
gereed75   Nice work and really nice looking car(s). Feels gr...   Jun 6 2016, 06:26 AM
mbseto   I've been tearing around town in this little ...   Jun 6 2016, 07:59 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:54 AM
