E Brake/Directional Flasher Etc. |
frankiec@outrageous.net |
Mar 31 2016, 03:09 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
Went out this AM and started the car. Everything was fine. The e brake light flashed on the dash. When I released the e brake arm the e brake light kept flashing. It has always gone off so... I got out of the car to see if the brake lights were flashing when the e brake was off. They were not. I then tried the turn signals, left and right and they both were working properly. Is there any way to disconnect the e brake flashing warning light on the dash? Also, where is the flasher located. The car is a 75 with a 3.2 in it. Any help will be greatly appreciated (IMG:style_emoticons/default/confused24.gif)
Thanks |
Garland |
Mar 31 2016, 10:18 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
The switch under the handle, gos to ground. The switch may depress, yet not be working. It's a very simple design, tendency to fail. Held in by one screw.
The wire to the switch ( if grounded along the way will turn on the light) runs along the left side of the seat, and behind the seat, to the center tunnel. In most cases, the wire is just laying there, or under the carpet as it should be. Easy to short out. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:55 PM |
