E Brake/Directional Flasher Etc. |
frankiec@outrageous.net |
Mar 31 2016, 03:09 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
Went out this AM and started the car. Everything was fine. The e brake light flashed on the dash. When I released the e brake arm the e brake light kept flashing. It has always gone off so... I got out of the car to see if the brake lights were flashing when the e brake was off. They were not. I then tried the turn signals, left and right and they both were working properly. Is there any way to disconnect the e brake flashing warning light on the dash? Also, where is the flasher located. The car is a 75 with a 3.2 in it. Any help will be greatly appreciated (IMG:style_emoticons/default/confused24.gif)
Thanks |
Valy |
Apr 3 2016, 02:41 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Please don't drive the car!
Your ebrake is probably fine. The other reason for the warning is more important. The reason for the warning light is low pressure in your brake system. You need to check your brakes, bleed them and then reset the pressure sensor on the master cylinder. The warning was triggered when pressure dropped in the braking hydraulic circuit and you must fix the cause. Check that all your calipers and master cylinder are dry. Check that the pedal cluster is dry. Bleed the brakes. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:43 AM |
