E Brake/Directional Flasher Etc. |
frankiec@outrageous.net |
Mar 31 2016, 03:09 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
Went out this AM and started the car. Everything was fine. The e brake light flashed on the dash. When I released the e brake arm the e brake light kept flashing. It has always gone off so... I got out of the car to see if the brake lights were flashing when the e brake was off. They were not. I then tried the turn signals, left and right and they both were working properly. Is there any way to disconnect the e brake flashing warning light on the dash? Also, where is the flasher located. The car is a 75 with a 3.2 in it. Any help will be greatly appreciated (IMG:style_emoticons/default/confused24.gif)
Thanks |
Steve |
Apr 3 2016, 12:39 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
The eBrake switch is to ground when actuated. If you disconnect the switch, the flasher should stop. If it doesn't you got other problems. Check the master cylinder switch, etc.
Apr 3 2016, 05:59 PM
Lo-Fi Version | Time is now: 8th June 2024 - 06:14 PM |
