SpecialK |
aircraft surgeon ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 ![]() ![]() |
I was re-reading my copy of Welder's Handbook because my practice welds on some scrap were weak as hell when trying to weld 18ga to some 12ga (rosette welds) to beef-up my seatbelt attach points that rusted out. (IMG:style_emoticons/default/headbang.gif) Needed a break (IMG:style_emoticons/default/beer.gif) to do some research and find out what I was doing wrong.
The author, Richard Finch, is big on brazing automotive sheetmetal repairs as opposed to fussion welding (MIG, Arc, etc.), particularly when it involves pre '80 cars that weren't assembled using HSS (High Strength Steel). He says that the high temps involved in fussion welding actually weakens the surrounding metal, where as the lower temps involved in brazing doesn't. You can't braze butt joints like you'd use to attach outer body panels, but the reinforcement kits like Mark's (Engman) inner long stiffener's and Brad's 10ga beasts would actually be much stronger (at the attach points). His example is taking 1" x 5" long strips of .060" mild steel, overlapping the ends by 1" and brazing them together. In a pull-test machine it takes over 3000 lbs. to pull them apart and it's always the base metal that breaks, never the brazed joint. Since lap joints are the preferred joint when brazing, and all of the weld points (holes) on the reinforcements are essentially lap joints, wouldn't it make sense to braze in the stiffeners rather than MIG weld? Or then there's always the possibility that everyone does braze their stiffeners in, and I'm just assuming they've been MIG'd (IMG:style_emoticons/default/slap.gif) Kevin |
SpecialK |
A guy I work with suggested upping the hole size in the 18ga from 3/16" to 1/2" in an attempt to liquify the heavier gauge metal first. I'll try all of the posted pointers and with any luck I won't have to use the (IMG:style_emoticons/default/headbang.gif) emoticon again.
Thanks for all of the input guys! Always appreciated!! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 5th July 2025 - 09:33 PM |
