| Jameel |
Mar 12 2016, 08:25 AM
Member ![]() ![]() Group: Members Posts: 98 Joined: 6-October 15 From: Iowa Member No.: 19,239 Region Association: None |
A few days ago I decided to take a closer look at my shift linkage, since my car has some serious issues. Took that rear cover off and found this: https://youtu.be/gtFysPUBIO0
I'm no engineer, but that looks nasty to me. I decided to fix it right. So yesterday I made a trip to 914 Limited and was treated quite well by Brad and Mike. Brad and I had exchanged a couple emails and calls and since I'm less than 3 hours from Peoria, I decided to kill two birds and simply drive in. Brad was kind enough to let me drive his daily 914 to see what a side shifter felt like. Took me about 1/3 mile to decide I would do the conversion. Brad and Mike walked me through a few of the finer points of the process, but this being my first time opening up a transaxle, I figured I'd try and document as much as possible. I've done a bunch of searches here (and at Pelican) but have not found much in terms of step-by-step. Brad's instructions were provided, and he invited me to call anytime for support, but I'll be taking pics anyway, so figured I'd start a thread. Can anyone point me to a thread where someone has documented the process? The best I've found so far is mikedsilva's, here. I could not find others. Sort of off topic too, but is there any way to get rid of the huge smileys window when composing a post? My composition pane is just tiny, like 1/4 the size of the smileys pane. |
| Dr Evil |
Apr 6 2016, 09:29 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Yer teeth are worn. Like saggy roofs. Look to the inner aspect, not the profile.
| Jameel |
Apr 7 2016, 06:19 AM
Yer teeth are worn. Like saggy roofs. Look to the inner aspect, not the profile. Aha, I get it. So not the shape of the gable end of the roof, but the condition of the ridge and the "roof surface". I just got a new 1st gear syncro and slider set from Brad, so I'll be swapping them out. |
Jameel Tail to Side Shift Conversion Rookie Mar 12 2016, 08:25 AM
Spoke Dr Evil here has a DVD on how to rebuild the 901 t... Mar 12 2016, 09:12 AM
The Cabinetmaker As for the smilie thing, just use the fast reply b... Mar 12 2016, 12:42 PM
396
A few days ago I decided to take a closer look at... Mar 12 2016, 12:44 PM
jcd914
Sort of off topic too, but is there any way to g... Mar 12 2016, 06:10 PM
stugray One trick:
You have to remove the engine bar to p... Mar 12 2016, 07:06 PM
Jameel Thanks everybody. I don't have any doubts that... Mar 12 2016, 08:16 PM
Jameel Took the day off to work on this. I spent the last... Mar 17 2016, 07:56 PM
Jameel Next I loosened the connection between the two shi... Mar 17 2016, 08:08 PM
Jameel Next I began removing the engine support bar to re... Mar 17 2016, 08:26 PM
SKL1 May I recommend while you're going to that tro... Mar 17 2016, 09:46 PM
Jameel
May I recommend while you're going to that tr... Mar 17 2016, 10:01 PM
ndfrigi You might want to just get a set of side shift par... Mar 17 2016, 10:05 PM
Jameel
You might want to just get a set of side shift pa... Mar 18 2016, 07:53 PM
rhodyguy The fact that most if not all of the bushings are ... Mar 18 2016, 08:38 AM
Jameel Managed to sneak in a couple hours on the 914 afte... Mar 18 2016, 08:19 PM
eyesright Good work and nice write up. We are waiting with..... Mar 19 2016, 04:41 AM
Jameel
Good work and nice write up. We are waiting with.... Mar 19 2016, 07:06 PM
Jameel So this is the first entire day I've been able... Mar 19 2016, 08:58 PM
SKL1 Wonder why you had to cut out that access hole in ... Mar 19 2016, 10:16 PM
brant
Wonder why you had to cut out that access hole in... May 21 2016, 12:11 AM
stugray
Wonder why you had to cut out that access hole i... May 21 2016, 11:43 AM
zambezi watch out on the reverse light switch. There shou... Mar 19 2016, 10:18 PM
Jameel
watch out on the reverse light switch. There sho... Mar 20 2016, 11:38 AM
Dr Evil Looking good!
Brad is a great guy and will al... Mar 20 2016, 10:55 AM
Jameel Had an hour today to fiddle with this. First up, I... Mar 21 2016, 09:36 PM
Jameel Moving along....I removed the side cover plate whi... Mar 26 2016, 08:44 AM
Dr Evil Hard to tell in the video, there looks to be some ... Mar 26 2016, 09:31 AM
Jameel Thanks for the info. As for recognizing noise, I ... Mar 26 2016, 03:03 PM
Jameel Dropped my flywheel off this morning, got it back ... Mar 29 2016, 09:46 PM
mepstein I just resurfaced mine for my six conversion. For ... Mar 29 2016, 09:57 PM
Dr Evil Things to consider:
1) Was the flywheel finished t... Mar 29 2016, 10:41 PM
Dr Evil Specs Mar 29 2016, 10:44 PM
Dave_Darling One thing I spotted early on--one of the wires goi... Mar 30 2016, 04:23 PM
Jameel
I just resurfaced mine for my six conversion. For... Mar 30 2016, 07:24 PM
76-914 :bump: Mar 31 2016, 08:09 AM
Jameel While studying the good Dr.'s DVD I've bee... Mar 31 2016, 06:22 PM
forrestkhaag Amen on Tangerine's products RE: side shift co... Mar 31 2016, 06:30 PM
stugray The dog teeth in those pics look pretty good.
One... Mar 31 2016, 07:17 PM
Jameel
On... Apr 6 2016, 08:30 AM
Phoenix-MN
[quote name='stugray' post='2323238' date='Mar 31... Apr 6 2016, 09:02 AM
Jameel My Panoramas only go back to '92. Any chance y... Apr 6 2016, 01:31 PM
db9146
My Panoramas only go back to '92. Any chance ... Apr 6 2016, 09:04 PM
Jameel
[quote name='Jameel' post='2326808' date='Apr 6 2... Apr 8 2016, 02:02 PM
oldie914 Your March 31st video shows visible end play on yo... Apr 7 2016, 01:52 AM
oldie914 Here are some more pictures showing indicators of ... Apr 7 2016, 03:27 AM
Jameel Thanks for the tips oldie914. I'll look closer... Apr 7 2016, 06:42 AM
Jameel Got some deliveries past couple days. I have every... Apr 8 2016, 08:28 PM
Jameel Lots to report today. Here's my setup for taki... Apr 9 2016, 05:58 PM
Jameel Well, I guess I screwed up. Sort of half assed cle... Apr 9 2016, 09:01 PM
Jameel Putting my case back together I had to reuse the b... Apr 12 2016, 08:07 PM
db9146 Here is the much better scan of the Pano article f... Apr 15 2016, 11:33 AM
Dr Evil Great job on this! Looking like you got it all... Apr 18 2016, 08:22 PM
Jameel Thank you Sir! I'm just waiting on some ne... Apr 19 2016, 07:45 AM
Jameel So I'm still waiting on a couple rubber boots ... May 8 2016, 07:36 AM
Jameel Made some good progress this week. Got the shifter... May 14 2016, 08:07 AM
Jameel Today I finished up the side shift conversion... May 15 2016, 08:40 PM
gereed75 Really nice write up. Thanks May 16 2016, 04:30 AM
Jameel Hopefully someone in my shoes someday will find it... May 17 2016, 07:49 AM
Porsche930dude I just picked up a junk yard side shift trans toda... May 20 2016, 09:39 PM
Jameel
I just picked up a junk yard side shift trans tod... May 21 2016, 05:58 AM
Dave_Darling
I just picked up a junk yard side shift trans tod... May 21 2016, 11:18 AM
Porsche930dude
I just picked up a junk yard side shift trans to... Jun 9 2016, 09:05 PM
Cuda911 Excellent work, Jameel, and excellent write-up. Th... May 20 2016, 11:54 PM
Jameel Thanks! Great news! Two nights ago I got e... May 21 2016, 05:47 AM
Jameel Just a quick follow up. I got my brakes bled prope... Jun 5 2016, 09:37 PM
gereed75 Nice work and really nice looking car(s). Feels gr... Jun 6 2016, 06:26 AM
mbseto
I've been tearing around town in this little ... Jun 6 2016, 07:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:01 PM |
