| JPA914 |
Apr 10 2016, 07:59 PM
Member ![]() ![]() Group: Members Posts: 81 Joined: 30-June 15 From: Houston, TX Member No.: 18,905 Region Association: Southwest Region |
Just got done doing this. I used the 3/8" butyl from Napa that seems to be recommended most often (part# MS 4196). Has anybody else who has used this ended up with a gap between the glass and engine lid seal? I pressed the glass in as far as it would go, but I think maybe this butyl is too thick and prevents the glass from seating as far back as it should (IMG:style_emoticons/default/confused24.gif)
PancakePorsche I think 3/8 would be way too thick. thickness of s... Apr 10 2016, 09:52 PM
dangrouche I have used 5/16" Apr 10 2016, 10:00 PM
Valy I used 3/8. No issue. Apr 10 2016, 10:25 PM
JPA914
I'm glad it worked fo... Apr 11 2016, 08:56 AM
Jett I used 3/8" and had to heat the tape to get t... Apr 11 2016, 09:02 AM
JPA914
I used 3/8" and had to heat the tape to get ... Apr 11 2016, 09:41 AM
tomrev You can also get a tube of the black poly sealant,... Apr 11 2016, 12:16 PM
Mikey914 Pretty much covered in detail and I still stock th... Apr 11 2016, 12:43 PM
JPA914
Pretty much covered in detail and I still stock t... Apr 11 2016, 01:27 PM
SA-914 The battery was used in the original wired install... Apr 11 2016, 07:16 PM
Mikey914 If you have heat issues. You may want to use the u... Apr 11 2016, 07:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:10 AM |
