Clutch adjustment question |
BPGREER |
Oct 4 2004, 10:26 PM
Member Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 |
Hello, this is my first post on this board. I just purchased a 73 silver 2.0 a couple of months back and have been working diligently to get her back on the road. Good news is we're there. She's running really well, I'm just trying to iron out some final details. I have to say, the months of frustrating work were worth it. I spent some time on the PP board, but after a week of lurking around here, thought I would jump in. I just met Brad last week at HPH and learned about this board. Anyhow, of course I'm looking for some advice...
First of all... I just realized I'm missing the wooden board that goes behind the pedal assembly. I rebuilt the assembly a couple of weeks ago, but with no pics, I didnt' realize anything was missing. I've looked at some old posts, and it sounds like it's a pretty essential piece. Does anyone know where I can find one? Also, I have to push the clutch pedal all the way to the floor to fully disengage it. Even then it sometimes grinds going into first or reverse. Does this sound like I need to adjust the cable? Do I need the wood piece first? Any tips would be great. BTW, I have to install a new rear window. I am very afraid of doing glass work. I've read tech articles and old threads on the subj, but any insights would still be great. Background on the car... as I said, its a 73 silver 2.0 with about 62000 orig miles. FI system, and all other stock options still intact. I bought it from the original owner who garaged it in 1987. Since I purchased it, I've replaced all of the original fuel lines, most ignition components, vacuum hoses, rebuilt pedal assembly, replaced throttle cable, adjusted valves, rebuilt calipers, replaced ms, installed new brake lines, a dry battery, and lots of other little stuff. |
McMark |
Oct 4 2004, 10:35 PM
Welcome! To bring the engagement point of the clutch closer to the "top" of the pedal tighten the nut at the throwout arm on the tranny. You'll need to hold the cable with pliers/vicegrips and use an 11 mm wrench to tighten the nut. Make sure there are two nuts. Always. Nylock or not. Two nuts.
The rear window is pretty easy. Make sure you clean everything really really well (acetone/thinner) and don't touch the sealing areas with you fingers after that. Finger oils will compromise the seal. Apply the butyl tape to the chassis and then lightly press the window into place. Don't press in the center of the window and go around the edges pressing firmly to seat it. DONE! |
Lo-Fi Version | Time is now: 10th June 2024 - 01:31 AM |
