Clutch adjustment question |
BPGREER |
Oct 4 2004, 10:26 PM
Member Group: Members Posts: 131 Joined: 29-September 04 From: SAN FRANCISCO Member No.: 2,857 |
Hello, this is my first post on this board. I just purchased a 73 silver 2.0 a couple of months back and have been working diligently to get her back on the road. Good news is we're there. She's running really well, I'm just trying to iron out some final details. I have to say, the months of frustrating work were worth it. I spent some time on the PP board, but after a week of lurking around here, thought I would jump in. I just met Brad last week at HPH and learned about this board. Anyhow, of course I'm looking for some advice...
First of all... I just realized I'm missing the wooden board that goes behind the pedal assembly. I rebuilt the assembly a couple of weeks ago, but with no pics, I didnt' realize anything was missing. I've looked at some old posts, and it sounds like it's a pretty essential piece. Does anyone know where I can find one? Also, I have to push the clutch pedal all the way to the floor to fully disengage it. Even then it sometimes grinds going into first or reverse. Does this sound like I need to adjust the cable? Do I need the wood piece first? Any tips would be great. BTW, I have to install a new rear window. I am very afraid of doing glass work. I've read tech articles and old threads on the subj, but any insights would still be great. Background on the car... as I said, its a 73 silver 2.0 with about 62000 orig miles. FI system, and all other stock options still intact. I bought it from the original owner who garaged it in 1987. Since I purchased it, I've replaced all of the original fuel lines, most ignition components, vacuum hoses, rebuilt pedal assembly, replaced throttle cable, adjusted valves, rebuilt calipers, replaced ms, installed new brake lines, a dry battery, and lots of other little stuff. |
SirAndy |
Oct 4 2004, 10:38 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(BPGREER @ Oct 4 2004, 09:26 PM) I just realized I'm missing the wooden board that goes behind the pedal assembly. welcome to the club! (IMG:style_emoticons/default/smilie_pokal.gif) first, don't drive it without the board! you'll need it to correctly adjust the pedal stops, otherwise you *WILL* brake your cables! as for the clutch, it could be as simple as adjusting it at the back, to get the dis-engage point up on the pedal, tighten the 11mm nut on the rear adjuster (make sure you have a 2nd 11mm as a double nut!). where in the pedal travel does the clutch engage when you let it out? is that also close to the floor? if that doesn't help, i'm afraid you might have broken your clutch-tube lose when you used the clutch without the stop (which is on the wooden board). in which case you need to have it welded back on before you can get the clutch adjusted right. (IMG:style_emoticons/default/wink.gif) Andy |
Lo-Fi Version | Time is now: 10th June 2024 - 02:59 AM |
