> Roll Bar in a street car discussion
Scott S
post Apr 14 2016, 10:21 AM
Small Member
Hi All. I posted this over on Pelican, thought it might be relevant here too.
I know there have been many discussions on the safety putting a roll bar/cage in a street driven car. I am not a racer, so it really didn't pertain to me at all. However, yesterday I saw first hand the injuries that can occur.
16 year old girl driving her dads Miata with him in the passenger seat. There is speculation that she was driving on her permit, practicing for her drivers license. She was driving at a slow speed, simply making a right hand turn on to a side street. She clipped the curb - something we all have done. Curb was tall enough that it shook the car pretty good (again, speculation, but knowing the corner I would guess a wheel would have been bent and the car knocked out of alignment ).
Both are in the hospital with concussions, one of them needed several stiches from injuries caused by their heads impacting the roll bar.
I don't know if the dad autocrossed the car or what, or if the bar was just for looks. I do know the car had stock seat belts.
Scary stuff.
post Apr 14 2016, 11:48 AM
Resident German
Proper padding and non-retractable seat belts are a must for a street car with a cage.
jasons
post Apr 14 2016, 02:26 PM
Jackstand Extraordinaire
QUOTE(SirAndy @ Apr 14 2016, 10:48 AM) *
I suppose you shouldn't be using a helmet as rollbar protection? It doesn't make much sense to me that you would use one safety device to protect yourself from another safety device.
post Apr 14 2016, 02:34 PM
Resident German
QUOTE(jasons @ Apr 14 2016, 01:26 PM) *
Wut?
With proper padding, a rollbar is not more dangerous than any other hard object in a car made of, wait for it, mostly metal!
Take any car with a fixed roof, remove the padding/plastic/cover from the frame above the door and what do you see? Metal ...
The rollbar in my 914 is no closer to my head than the door frame in my 2002 Jetta. Or 2012 Tiguan. Plenty of places to hit with my head in those cars.
And i don't see anyone here driving around with a helmet in their daily driver. Well, except Larmo maybe ...
DBCooper
post Apr 14 2016, 10:16 PM
14's in the 13's with ATTITUDE
QUOTE(SirAndy @ Apr 14 2016, 12:34 PM) *
You sure about that? When you put a rollbar or cage into any car by definition it's inside the existing sheet metal, meaning you've reduced the clearance inside the sides and below the roof, in all directions closer to your head. Comparing Jettas to 914's is apples and oranges, the only correct comparison is Jetta with roll bar and Jetta without, or 914 with and without. If your head is closer to something rigid there's more likelihood first that it will be hit in an impact, and then that the impact be of more force. Same car, less clearance, means more risk and more damage.
post Apr 15 2016, 11:14 AM
Resident German
QUOTE(DBCooper @ Apr 14 2016, 09:16 PM) *
Yes, i am. Last time i checked, my 914 didn't have any metal above the door from the factory, so no, it's not apples and oranges.
The cage adds metal where a sedan already has metal.
Which makes this a valid comparison.
I did in fact compare the head clearance between the cage in my 914 and my other two cars, the Jetta and Tiguan (Yes, i'm weird that way) and they are pretty much the same.
DBCooper
post Apr 15 2016, 11:19 AM
QUOTE(SirAndy @ Apr 15 2016, 09:14 AM) *
Wait, Andy, you say the 914 has no metal above the door from the factory, but you're going to add some there, spaced so it's even closer to your head, and that's going to be as safe as before, when there was none? Sorry, I don't follow.
stugray
post Apr 15 2016, 11:29 AM
QUOTE(DBCooper @ Apr 15 2016, 11:19 AM) *
He is SAYING that the metal that is NOW in his 914 is NO CLOSER than the METAL in his other cars.
I also have more headroom in my 914 than in ANY of my other cars except my Suburban.
I have a full rollcage in my car that I drive on the street.
It is covered everywhere that my head or arms could make contact with the expensive high density SFI rated foam padding.
Everywhere else it has the less expensive low density foam.
It is difficult to see any piece of my roll structure metal because it is ALL covered.
DBCooper
post Apr 15 2016, 03:27 PM
QUOTE(stugray @ Apr 15 2016, 09:29 AM) *
That's totally irrelevant. The comparison is the change you make to the SAME car when you put in a bar or cage, from before to after. You've just 1) put metal where there was no metal before, and 2) moved the contact point closer to your unprotected head. Both of those things mean that car, whether it's a 914 or a Suburban, is less safe than it was before it got the cage.
Yeah, but that's a little like me saying "Don't worry, I'm going to hit you in the head with this aluminum baseball bat, but it'll be O.K. because I'll wrap it in high density SFI rated foam padding." Look, it's a free country and you can do whatever you like, but being hit in the head with a baseball bat, wrapped in foam or not, is not going to turn out well. That's a reasonable statement, isn't it?
Sure, it's also possible that the cage may save your life in an accident, but I think statistics (from studies of airbags) all suggest you're far, far more likely to die of head trauma from contacting something inside the cabin than you are from any type of structural collapse. Means the odds are really not in your favor when you put even more rigid metal points of contact into the cabin, especially close to your head, covered with foam or not.
But on the other hand 914's aren't logical or that safe to begin with, and cages are cool, so do what you want.
post Apr 15 2016, 03:33 PM
Resident German
QUOTE(DBCooper @ Apr 15 2016, 02:27 PM) *
No, it's not irrelevant.
It just means you're making a big argument out of something that really isn't a big deal.
I don't see you telling everyone who owns a sedan how they're going to die a horrible death because there is metal in their car roof.
Scott S   Roll Bar in a street car discussion   Apr 14 2016, 10:21 AM
ThePaintedMan   I drive my car as little on the street as possib...   Apr 14 2016, 11:12 AM
brant   sad story... I hope there is no further medical co...   Apr 14 2016, 11:29 AM
SirAndy   Proper padding and non-retractable seat belts are ...   Apr 14 2016, 11:48 AM
jasons   Proper padding and non-retractable seat belts are...   Apr 14 2016, 02:26 PM
SirAndy   Proper padding and non-retractable seat belts are ...   Apr 14 2016, 02:34 PM
jasons   Wut? With proper padding, a rollbar is not more...   Apr 14 2016, 02:52 PM
DBCooper   The rollbar in my 914 is no closer to my head tha...   Apr 14 2016, 10:16 PM
SirAndy   You sure about that? Yes, i am. Last time i check...   Apr 15 2016, 11:14 AM
DBCooper   You sure about that? Yes, i am. Last time i chec...   Apr 15 2016, 11:19 AM
stugray   [quote name='SirAndy' post='2331023' date='Apr 15...   Apr 15 2016, 11:29 AM
SirAndy   He is SAYING that the metal that is NOW in his 914...   Apr 15 2016, 01:40 PM
r_towle   He is SAYING that the metal that is NOW in his 91...   Apr 15 2016, 02:51 PM
DBCooper   He is SAYING that the metal that is NOW in his 91...   Apr 15 2016, 03:27 PM
SirAndy   He is SAYING that the metal that is NOW in his 914...   Apr 15 2016, 03:33 PM
stugray   That's totally irrelevant. The comparison is...   Apr 15 2016, 06:11 PM
Larmo63   :agree: ^^^That^^^   Apr 14 2016, 12:25 PM
RobW   A bar needs to be padded and ideally not within he...   Apr 14 2016, 06:39 PM
Elliot Cannon   Reasons to have a roll bar/cage in your street car...   Apr 14 2016, 11:15 PM
Garland   I remember going down hill tobogganing (holds 4) a...   Apr 14 2016, 11:51 PM
wes   I can't wait to see a guy driving down the str...   Apr 15 2016, 12:20 AM
RobW   I can't wait to see a guy driving down the st...   Apr 15 2016, 06:34 AM
Geezer914   If you are going to do all the work to put in a ro...   Apr 15 2016, 05:51 AM
DBCooper   But I never said that, Andy. Did you read the fir...   Apr 15 2016, 05:58 PM
SirAndy   But I never said that, Andy. Did you read the fir...   Apr 15 2016, 07:36 PM
DBCooper   But that wasn't in a 914 and we don't kno...   Apr 15 2016, 08:38 PM
SirAndy   What i am telling you is that in my car my head i...   Apr 15 2016, 10:46 PM
DBCooper   Why did my 914 become less safe when the distance...   Apr 16 2016, 10:07 AM
stugray   Not really. Without a roll bar there was nothing...   Apr 16 2016, 10:20 AM
RobW   :beer3: :beer3: :beer3:   Apr 15 2016, 07:48 PM
Elliot Cannon   This has been a very educational thread. I just w...   Apr 15 2016, 07:51 PM
SirAndy   This has been a very educational thread. I just w...   Apr 15 2016, 07:56 PM
VegasRacer   This has been a very educational thread. I just ...   Apr 15 2016, 09:53 PM
Elliot Cannon   [quote name='SirAndy' post='2331305' date='Apr 15...   Apr 16 2016, 07:06 AM
Elliot Cannon   This has been a very educational thread. I just ...   Apr 16 2016, 07:02 AM
r_towle   Color glossy photos with measurements would have b...   Apr 15 2016, 08:19 PM
Garland   I Would think hitting a roll bar. with your head i...   Apr 15 2016, 11:25 PM
mgp4591   If your head hits metal at speed, any metal, it...   Apr 16 2016, 01:25 AM
sixnotfour   factory 959 :beer3:   Apr 16 2016, 04:59 AM
Cracker   Its certainly nothing to do flippantly. I rebuilt ...   Apr 16 2016, 06:05 AM
jd74914   I see allot of Miatas with roll bars (I believe t...   Apr 16 2016, 09:10 AM
campbellcj   I occasionally take my car on public roads with th...   Apr 16 2016, 09:20 AM
Steve   :deadhorse: This has been brought up many times b...   Apr 16 2016, 09:42 AM
sixnotfour   The End They wonder the same thing Miata guys th...   Apr 16 2016, 10:28 AM
jeff   At least everyone is enthusiastic about this discu...   Apr 16 2016, 10:29 AM
- Lo-Fi Version Time is now: 13th July 2025 - 08:00 AM
