> Roll Bar in a street car discussion
Scott S
post Apr 14 2016, 10:21 AM
Small Member
Hi All. I posted this over on Pelican, thought it might be relevant here too.
I know there have been many discussions on the safety putting a roll bar/cage in a street driven car. I am not a racer, so it really didn't pertain to me at all. However, yesterday I saw first hand the injuries that can occur.
16 year old girl driving her dads Miata with him in the passenger seat. There is speculation that she was driving on her permit, practicing for her drivers license. She was driving at a slow speed, simply making a right hand turn on to a side street. She clipped the curb - something we all have done. Curb was tall enough that it shook the car pretty good (again, speculation, but knowing the corner I would guess a wheel would have been bent and the car knocked out of alignment ).
Both are in the hospital with concussions, one of them needed several stiches from injuries caused by their heads impacting the roll bar.
I don't know if the dad autocrossed the car or what, or if the bar was just for looks. I do know the car had stock seat belts.
Scary stuff.
DBCooper
post Apr 15 2016, 05:58 PM
14's in the 13's with ATTITUDE
But I never said that, Andy. Did you read the first post in this thread? Bumped a curb and two people in the hospital? That's not a big enough deal? Like I said, do whatever you want, but people do get hurt so don't make that choice without at least knowing the issues. That's not fair? You think it's better to not talk about it at all?
post Apr 15 2016, 07:36 PM
Resident German
QUOTE(DBCooper @ Apr 15 2016, 04:58 PM) *
But that wasn't in a 914 and we don't know how that cage was build and how far their heads were from the cage and if it was padded.
That's A LOT of unknowns to make such a blanket statement!
What i am telling you is that in my car my head is no closer to my (padded) roll bar than it is to (covered) solid metal in my daily driver sedan.
I still have no idea why you insist that one somehow is going to kill me while the other one is perfectly acceptable?
DBCooper
post Apr 15 2016, 08:38 PM
QUOTE(SirAndy @ Apr 15 2016, 05:36 PM) *
Not really. Without a roll bar there was nothing there for their heads to hit. They added a bar TO THE SAME CAR, there was then something for their head to hit and they hit their heads. IN THE SAME CAR. They changed the car and the change made it less safe.
Yes, you did say that, but again, the comparison I've made has been in the SAME car. Before adding a bar (in any car) there's clearance, adding the bar reduces the clearance IN THAT SAME CAR, so your head can then hit where it wouldn't have before IN THAT SAME CAR. It's had a hazzard added so in that aspect is less safe than it was before.
I never said that even once, so certainly never insisted. From the beginning I've said that adding a bar or cage changes and reduces the clearance IN THE SAME CAR. Your other car can have airbags, be the Queen Mary or a blimp, it's irrelevant because I'm talking about the addition of a bar/cage changing the configuration IN THAT SAME CAR.
Look, you don't get anything for free. A roll cage can make your car stiffer, may protect better from being t-boned, from rollover and so on. But to get something you have to give up something, and that something is contact with your head. If that works for you, great, as long as you're aware of it and accept it it's not a problem, but it's not rational to pretend that it doesn't exist.
post Apr 15 2016, 10:46 PM
Resident German
QUOTE(DBCooper @ Apr 15 2016, 07:38 PM) *
But why is the exact same distance a hazard "IN THE SAME CAR" but not in another car?
I just don't get it ...
Why did my 914 become less safe when the distance from the rollbar to my head is no closer than the distance from the door-frame on my Jetta to my head?
What makes that same distance an acute "you're going to die" hazard in a 914 but not in a Jetta?
I am profoundly confused by your logic.
You fully accept the margin of hazard in my Jetta but when i add something to my 914 that brings me within the same margin of hazard, it's instagib brainmush unsafe at any speed.
DBCooper
post Apr 16 2016, 10:07 AM
QUOTE(SirAndy @ Apr 15 2016, 08:46 PM) *
I didn't say that Andy, you did. Re-read the first post. The discussion was about wisdom of adding a bar or cage to a street car, in other words modifying the SAME car, before and after. I have no idea about Jettas, but wasn't your Jetta designed by an engineer specifically for passenger survivability? Different seats and belts? Cabin crush differently? More and different pladding inside, all different materials? Have airbags? In fact EVERYTHING about the car acting differently in a crash? It's not as simple as clearance distance, your question is about apples to oranges, and the answer is 'who knows?' Which is why the discussion was about putting a roll bar into a street car and not why Jettas are safer than 914's. That's a totally different discussion.
Again, I never talked about Jettas. But by the same before/after logic if you did add a roll cage to your Jetta you're creating exactly the same situation with your Jetta, by reducing clearances. More hazard than a 914? I don't know, can't know, you'd need to talk to someone else about that. But more hazzard in the Jetta with the cage than without? Before and after? Yes, the same logic applies, and worse, if you block the Jetta's airbags.
My point has been that with that modification you're reducing clearances in THAT car, be it 914 or Jetta, which, by itself, makes THAT car less safe, before and after. In a race car you have a race seat, restricting movement, race belts, restricting movement, and a helmet, for exactly the type of impact described in the first post. If you add all those things to the street car along with the bar/cage then yes, safer. Without them the bar/cage adds a new safety hazard to the same car.
I didn't invent any of this, you know it all already because it's conventional wisdom. So is conventional wisdom incorrect? How is that?
Scott S   Roll Bar in a street car discussion   Apr 14 2016, 10:21 AM
ThePaintedMan   I drive my car as little on the street as possib...   Apr 14 2016, 11:12 AM
brant   sad story... I hope there is no further medical co...   Apr 14 2016, 11:29 AM
SirAndy   Proper padding and non-retractable seat belts are ...   Apr 14 2016, 11:48 AM
jasons   Proper padding and non-retractable seat belts are...   Apr 14 2016, 02:26 PM
SirAndy   Proper padding and non-retractable seat belts are ...   Apr 14 2016, 02:34 PM
jasons   Wut? With proper padding, a rollbar is not more...   Apr 14 2016, 02:52 PM
DBCooper   The rollbar in my 914 is no closer to my head tha...   Apr 14 2016, 10:16 PM
SirAndy   You sure about that? Yes, i am. Last time i check...   Apr 15 2016, 11:14 AM
DBCooper   You sure about that? Yes, i am. Last time i chec...   Apr 15 2016, 11:19 AM
stugray   [quote name='SirAndy' post='2331023' date='Apr 15...   Apr 15 2016, 11:29 AM
SirAndy   He is SAYING that the metal that is NOW in his 914...   Apr 15 2016, 01:40 PM
r_towle   He is SAYING that the metal that is NOW in his 91...   Apr 15 2016, 02:51 PM
DBCooper   He is SAYING that the metal that is NOW in his 91...   Apr 15 2016, 03:27 PM
SirAndy   He is SAYING that the metal that is NOW in his 914...   Apr 15 2016, 03:33 PM
stugray   That's totally irrelevant. The comparison is...   Apr 15 2016, 06:11 PM
Larmo63   :agree: ^^^That^^^   Apr 14 2016, 12:25 PM
RobW   A bar needs to be padded and ideally not within he...   Apr 14 2016, 06:39 PM
Elliot Cannon   Reasons to have a roll bar/cage in your street car...   Apr 14 2016, 11:15 PM
Garland   I remember going down hill tobogganing (holds 4) a...   Apr 14 2016, 11:51 PM
wes   I can't wait to see a guy driving down the str...   Apr 15 2016, 12:20 AM
RobW   I can't wait to see a guy driving down the st...   Apr 15 2016, 06:34 AM
Geezer914   If you are going to do all the work to put in a ro...   Apr 15 2016, 05:51 AM
DBCooper   But I never said that, Andy. Did you read the fir...   Apr 15 2016, 05:58 PM
SirAndy   But I never said that, Andy. Did you read the fir...   Apr 15 2016, 07:36 PM
DBCooper   But that wasn't in a 914 and we don't kno...   Apr 15 2016, 08:38 PM
SirAndy   What i am telling you is that in my car my head i...   Apr 15 2016, 10:46 PM
DBCooper   Why did my 914 become less safe when the distance...   Apr 16 2016, 10:07 AM
stugray   Not really. Without a roll bar there was nothing...   Apr 16 2016, 10:20 AM
RobW   :beer3: :beer3: :beer3:   Apr 15 2016, 07:48 PM
Elliot Cannon   This has been a very educational thread. I just w...   Apr 15 2016, 07:51 PM
SirAndy   This has been a very educational thread. I just w...   Apr 15 2016, 07:56 PM
VegasRacer   This has been a very educational thread. I just ...   Apr 15 2016, 09:53 PM
Elliot Cannon   [quote name='SirAndy' post='2331305' date='Apr 15...   Apr 16 2016, 07:06 AM
Elliot Cannon   This has been a very educational thread. I just ...   Apr 16 2016, 07:02 AM
r_towle   Color glossy photos with measurements would have b...   Apr 15 2016, 08:19 PM
Garland   I Would think hitting a roll bar. with your head i...   Apr 15 2016, 11:25 PM
mgp4591   If your head hits metal at speed, any metal, it...   Apr 16 2016, 01:25 AM
sixnotfour   factory 959 :beer3:   Apr 16 2016, 04:59 AM
Cracker   Its certainly nothing to do flippantly. I rebuilt ...   Apr 16 2016, 06:05 AM
jd74914   I see allot of Miatas with roll bars (I believe t...   Apr 16 2016, 09:10 AM
campbellcj   I occasionally take my car on public roads with th...   Apr 16 2016, 09:20 AM
Steve   :deadhorse: This has been brought up many times b...   Apr 16 2016, 09:42 AM
sixnotfour   The End They wonder the same thing Miata guys th...   Apr 16 2016, 10:28 AM
jeff   At least everyone is enthusiastic about this discu...   Apr 16 2016, 10:29 AM
- Lo-Fi Version Time is now: 13th July 2025 - 07:53 AM
