| catsltd |
Apr 15 2016, 07:42 AM
Member ![]() ![]() Group: Members Posts: 181 Joined: 7-June 15 From: Calgary Alberta Member No.: 18,814 Region Association: None |
Installed new front wheel bearings last year,and checked them and there shot???.
Im talking couple hundred miles. Why driving down the highway had a low pitched howling. Started checked the rotors by touching them and 1 was really really hot,let it cool down and drove home. Pulled the wheel and saw the bearing was shot,and had marks on it where the spacer between the bearing and the lock nut was rubbing on it. So I ordered my new bearing set etc and waiting to install,but I cant find a decent write up on how to do it properly. Since I have no picture of how the wheel bearing assembly looks like,I am installing it the same way it is on my wheel,but even that could be wrong. I have installed new rotors,pads etc and spline or hub has no marks etc. So I need to know the order of how the parts are assembled,and whether or not the big seal that comes with it goes on front or back of bearing.Any help would be appreciated,especially a diagram. Sorry for the long winded post just tring to explain my problem in laymans term. Thanks Grant |
| ThePaintedMan |
Apr 18 2016, 11:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Then why the allowable (recommend) play?
| Elliot Cannon |
Apr 18 2016, 12:02 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Then why the allowable (recommend) play? Recommended play? I don't recall ever reading or being told about "play". If the bearings are adjusted properly and you grab the tire at top and bottom and try to wiggle it back and forth there should be NO play at all. Being able to slide the washer back and forth a bit indicates the bearings are at the recommended "tightness". |
catsltd Wheel bearing Apr 15 2016, 07:42 AM
zambezi sounds like the bearing races were not seated all ... Apr 15 2016, 08:43 AM
cary Your right not much out there.
Use this ............. Apr 15 2016, 08:52 AM
Elliot Cannon Sounds like you might have tightened the bearing n... Apr 15 2016, 09:13 AM
Kansas 914
Sounds like you might have tightened the bearing ... Apr 15 2016, 09:37 AM
ThePaintedMan :agree: too. If you follow Elliott's method, ... Apr 15 2016, 09:39 AM
porschetub
:agree: too. If you follow Elliott's method,... Apr 15 2016, 01:39 PM
6freak
:agree: too. If you follow Elliott's method,... Apr 18 2016, 09:34 AM
catsltd Sounds like I have a plan.
Thanks for all the supp... Apr 15 2016, 10:15 AM
RobW
Recom... Apr 18 2016, 12:25 PM
ThePaintedMan
Recom... Apr 18 2016, 05:34 PM
6freak Clearly there should be no discernable lateral pla... Apr 18 2016, 07:25 PM
SirAndy Or you could use the scientific method:
- Tighten... Apr 18 2016, 12:27 PM
sixnotfour make sure your calipers aren't sticking ..the ... Apr 18 2016, 02:21 PM
6freak i agree with Andy ,Rob and Elliot....the way I do ... Apr 18 2016, 02:26 PM
catsltd Thanks for the advice.
Problems:
1.I tightened the... Apr 18 2016, 02:58 PM
6freak
Problems:
1.I tightened th... Apr 18 2016, 03:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:15 PM |
