Removal of 914-6 Heat Exchangers, How to get the three nuts off? |
Daiberl |
Apr 24 2016, 01:14 PM
Senior Member Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
In the process of removing the HEs from the 2.2 engine, was able to open the Allen fine but there are three bolts (2 passenger side and 1 driver side) at the front cylinders, how to get them off, seems to be impossible to get a ratchet in and my wrenches see to also not fit very well. Afraid I might damage one of the nuts.
rhodyguy |
Apr 24 2016, 02:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once?
Daiberl |
Apr 24 2016, 03:24 PM
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once? Sprayed them more than once, the problem is that they are really hard to reach. Will check to get a flex socket and then we will see. |
Kaeferfreund |
Apr 26 2016, 02:02 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once? Sprayed them more than once, the problem is that they are really hard to reach. Will check to get a flex socket and then we will see. Hi! You got them off now, but before you sprayed them with WD 40? Hmmm...the best I know is that one: Caramba Rasant Rostlöser/swift shock rust remover: http://www.caramba.eu/en/products/swift-shock-rust-remover/ Nothing which was not to remove with that fantastic spray Darauf ein König (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:50 AM |
