| Gunn1 |
Apr 11 2016, 06:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
After hearing it and reading about it....... the factory EFI is the recommended way to go with a stock engine from a performance standpoint. That being said If you were building a carbureted car what would be the carb manufacturer, number of carbs and type of Intake manifolds you would choose for the build?
| Mark Henry |
Apr 12 2016, 06:37 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head
BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. |
| Gunn1 |
Apr 28 2016, 06:58 PM
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. Thinking of putting these on the 1.8 I will be rebuilding. I believe they were on the 2.0 liter I got as part of the package deal. but from what I have read these carbs are probably better suited for the 1.8 or 1.7 liter rather than the 2.0 Am I thinking right? Thanks |
| Gunn1 |
Apr 28 2016, 07:00 PM
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. Thinking of putting these on the 1.8 I will be rebuilding. I believe they were on the 2.0 liter I got as part of the package deal. but from what I have read these carbs are probably better suited for the 1.8 or 1.7 liter rather than the 2.0 Am I thinking right? Another better photo Thanks |
| porschetub |
Apr 28 2016, 11:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. Thinking of putting these on the 1.8 I will be rebuilding. I believe they were on the 2.0 liter I got as part of the package deal. but from what I have read these carbs are probably better suited for the 1.8 or 1.7 liter rather than the 2.0 Am I thinking right? you could but the stock vents are very small,just sold a near new set to a mate doing a 1600 bus engine with big valve heads so that's the range of them really,same as the ICT webers they have small vents also. If you buy this set-up cheap enough you could go to aircooled.net and get rebuild kits and larger venturi's from them along with a suitable jetting package for your engine they should run ok . Failing that get some Dellorto's as mentioned. Another better photo Thanks |
OU812 Solex, weber, ect. Getting the proper Carbs Apr 11 2016, 06:22 PM
OU812
After hearing it and reading about it....... the ... Apr 11 2016, 06:37 PM
type2man 36 or 40 dells would be ideal. I have 40's and... Apr 11 2016, 06:41 PM
OU812 How about the Brazilian Solex carbs. Apr 11 2016, 07:16 PM
Ansbacher Am running Dellorto 40s with 32 vents on a '74... Apr 11 2016, 07:24 PM
porschetub Dellorto's,better more modern design that the ... Apr 11 2016, 10:27 PM
OU812 Yes....wanting to know how this set up would work ... Apr 12 2016, 04:23 AM
OU812
Although the kadrons (solex) work good on a type ... Apr 30 2016, 03:57 PM
BK911 I have empi hpmx 40s on a 1.7 and love them. Abou... Apr 29 2016, 04:10 AM
flmont where do ya get dells,..??? Apr 30 2016, 01:34 PM
porschetub
the 36 and 40mm wer... Apr 30 2016, 04:14 PM
OU812
the 36 and 40mm we... May 1 2016, 05:06 AM
JOEPROPER
There are a set on s... May 1 2016, 06:42 AM
era vulgaris
There's several... May 1 2016, 10:50 AM
BK911 Check on the samba for the kaddy shack.he speciali... May 1 2016, 06:27 AM
RonnieJ I put a pair of Kadron/Solex 40's on my 1.7 th... May 1 2016, 12:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:55 PM |
