And now the fuel pump?, It's always something |
iankarr |
Apr 29 2016, 10:57 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
I finally get the ignition module replaced and the engine fires up! I (definitely) turn off the car, go grab a beer and come back in half hour to begin tuning the carbs and it won't turn over. Doesn't seem to be fuel getting to the carbs. And I don't hear the fuel pump whine with the key in the "on" position before starting. I swapped the relays around on the board, but no luck. I assume the pump is dead. Or do you guys have any other suggestions? Thing is...the PO relocated the pump...I guess to the front cause I can't find it anywhere else. I can't see it through the hole under the tank or from the top. Anything else I should try before pulling the tank??? If I do need a new pump, is there a low pressure one you recommend that I can pick up at a FLAPS? UGHHHHH! Thanks! |
Rob-O |
Apr 30 2016, 03:48 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Is the battery still charged? If so an no cranking, I'd seriously suspect the ignition switch (you called it a module but I'm assuming you mean the switch) you just replaced.
Lo-Fi Version | Time is now: 1st June 2024 - 10:32 PM |
