| Gunn1 |
Apr 11 2016, 06:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
After hearing it and reading about it....... the factory EFI is the recommended way to go with a stock engine from a performance standpoint. That being said If you were building a carbureted car what would be the carb manufacturer, number of carbs and type of Intake manifolds you would choose for the build?
| Mark Henry |
Apr 12 2016, 06:37 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head
BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. |
| Gunn1 |
Apr 30 2016, 03:57 PM
Although the kadrons (solex) work good on a type 1 up to a mild cam and 1776cc it wouldn't be my choice for a type 4. Main reason is T4 heads flow way more than a T1 head BTW I've used kads many times. Get the dells or webers, better yet keep the FI and do a MegaSquirt brain. I think now I am starting to get it....These Kadrons (Solex) would work out ok on my 1.7 or 1.8 liter. But the factory EFI in the proper tune is still preferred over carbs and as good as it gets for a stock engine set up.....More desirable too. |
OU812 Solex, weber, ect. Getting the proper Carbs Apr 11 2016, 06:22 PM
OU812
After hearing it and reading about it....... the ... Apr 11 2016, 06:37 PM
type2man 36 or 40 dells would be ideal. I have 40's and... Apr 11 2016, 06:41 PM
OU812 How about the Brazilian Solex carbs. Apr 11 2016, 07:16 PM
Ansbacher Am running Dellorto 40s with 32 vents on a '74... Apr 11 2016, 07:24 PM
porschetub Dellorto's,better more modern design that the ... Apr 11 2016, 10:27 PM
OU812 Yes....wanting to know how this set up would work ... Apr 12 2016, 04:23 AM
OU812
Although the kadrons (solex) work good on a type ... Apr 28 2016, 06:58 PM
OU812
[quote name='Mark Henry' post='2329487' date='Apr... Apr 28 2016, 07:00 PM
porschetub
[quote name='OU812' post='2337439' date='Apr 28 2... Apr 28 2016, 11:25 PM
BK911 I have empi hpmx 40s on a 1.7 and love them. Abou... Apr 29 2016, 04:10 AM
flmont where do ya get dells,..??? Apr 30 2016, 01:34 PM
porschetub
the 36 and 40mm wer... Apr 30 2016, 04:14 PM
OU812
the 36 and 40mm we... May 1 2016, 05:06 AM
JOEPROPER
There are a set on s... May 1 2016, 06:42 AM
era vulgaris
There's several... May 1 2016, 10:50 AM
BK911 Check on the samba for the kaddy shack.he speciali... May 1 2016, 06:27 AM
RonnieJ I put a pair of Kadron/Solex 40's on my 1.7 th... May 1 2016, 12:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:51 PM |
