| HansJan |
Apr 28 2016, 08:03 PM
Member ![]() ![]() Group: Members Posts: 403 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious. Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed. I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions. Br, Hans Jan |
| r_towle |
May 2 2016, 04:55 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I think Chris is right, the 103's just about touch the studs and yours appear to have some room.
I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich |
| Mark Henry |
May 2 2016, 09:39 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I think Chris is right, the 103's just about touch the studs and yours appear to have some room. I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich Nickies would be silver aluminum, a magnet will not stick to them, they would also have ARP head studs with 12 point nuts. (IMG:http://www.914world.com/bbs2/uploads/post-26-1455467774.jpg) This pic will give you an idea how much material is left when you machine for the 103 register. (IMG:http://www.914world.com/bbs2/uploads/post-26-1403278590.jpg) |
| 0396 |
May 2 2016, 10:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I think Chris is right, the 103's just about touch the studs and yours appear to have some room. I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich Nickies would be silver aluminum, a magnet will not stick to them, they would also have ARP head studs with 12 point nuts. (IMG:http://www.914world.com/bbs2/uploads/post-26-1455467774.jpg) This pic will give you an idea how much material is left when you machine for the 103 register. (IMG:http://www.914world.com/bbs2/uploads/post-26-1403278590.jpg) Boy, you even have the ARP case bolts too. Way too go . |
| Mark Henry |
May 2 2016, 10:38 PM
Boy, you even have the ARP case bolts too. Way too go . Thanks, she is a brute in a 1700lb beetle. Made my my own heads as well, 44x38, SSI valves, dual springs with 12mm plugs...but then what do I know I use RTV.... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) Attached image(s)
Hans Jan What kind of Cylinders are these? Apr 28 2016, 08:03 PM
396 Sorry to hear of your car. In regards to your ques... Apr 28 2016, 08:09 PM
rhcb914 Those are AA cylinders.
http://aapistons.com/ Apr 28 2016, 08:11 PM
ThePaintedMan :agree:
At this point, I'd be willing to bet... Apr 28 2016, 08:16 PM
Hans Jan Even though this is bad news, you guys are the bes... Apr 28 2016, 08:35 PM
Valy The orange silicon tells a lot about who built thi... Apr 28 2016, 08:35 PM
914Sixer You will have to disassemble the engine to find ou... Apr 28 2016, 08:51 PM
Mueller
You will have to disassemble the engine to find o... Apr 28 2016, 09:00 PM
Mueller Nickies are machined, those are cast cylinders, I ... Apr 28 2016, 08:59 PM
rick 918-S What video? What did I miss? Maybe not the engine ... Apr 28 2016, 09:05 PM
Racer Chris Those aren't 103s.
The case registers are pro... Apr 29 2016, 04:56 AM
Hans Jan
Those aren't 103s.
The case registers are pr... May 2 2016, 01:12 PM
jdm914 It might be worth while to have a long talk with t... Apr 29 2016, 09:18 AM
Mark Henry
It might be worth while to have a long talk with ... Apr 29 2016, 09:36 AM
Valy
It might be worth while to have a long talk with... Apr 29 2016, 10:03 AM
Mark Henry
[quote name='Mark Henry' post='2337719' date='Apr... Apr 29 2016, 10:38 AM
[quote name='Mark Henry' post='2337719' date='Ap... Apr 29 2016, 10:44 AM
jdm914
[quote name='Mark Henry' post='2337719' date='Ap... Apr 29 2016, 10:54 AM
Mark Henry If you paid nickies coin for that you have been ho... Apr 29 2016, 09:24 AM
sixnotfour
If you paid nickies coin for that you have been h... Apr 29 2016, 10:09 AM
sixnotfour
If you paid nickies coin for that you have been ... Apr 29 2016, 01:49 PM
sixnotfour
[quote name='sixnotfour' post='2337732' date='Apr... May 4 2016, 03:38 PM
boxsterfan Who sold you the car and are they a member here on... Apr 29 2016, 09:29 AM
iwanta914-6 More about this unfortunate event in this thread:
... Apr 29 2016, 09:34 AM
Mark Henry
More about this unfortunate event in this thread:... Apr 29 2016, 09:40 AM
Mark Henry Point is I've never seen a failure.
It was how... Apr 29 2016, 11:07 AM
JamesM
It was ho... May 2 2016, 11:46 PM
Mark Henry BTW just an FYI I've also used both Jake's... Apr 29 2016, 11:33 AM
iwanta914-6 Well, this thread went a bit off topic... Turned i... Apr 29 2016, 11:37 AM
Mark Henry
Well, this thread went a bit off topic... Turned ... Apr 29 2016, 12:01 PM
jdm914 Good point... It is unfortunate that this new 914 ... Apr 29 2016, 12:41 PM
Mark Henry
Good point... It is unfortunate that this new 914... Apr 29 2016, 01:28 PM
Puebloswatcop I think we should all concentrate on finding the S... Apr 29 2016, 01:13 PM
Valy @Mark: So did the guy that rebuilt that engine...
... Apr 29 2016, 01:51 PM
Mark Henry
@Mark: So did the guy that rebuilt that engine...... Apr 29 2016, 02:27 PM
Valy
@Mark: So did the guy that rebuilt that engine..... Apr 29 2016, 04:59 PM
Mark Henry
[quote name='Mark Henry' post='2337862' date='Apr... Apr 30 2016, 06:50 AM
Valy
[quote name='Mark Henry' post='2337862' date='Ap... Apr 30 2016, 04:29 PM
r_towle
@Mark: So did the guy that rebuilt that engine..... Apr 29 2016, 06:48 PM
Hans Jan Sorry. I havent visit the site for a few days, and... May 2 2016, 01:06 PM
r_towle Well, the best way is to measure the piston diamet... May 2 2016, 04:52 PM
porschetub
I think Chris is right, the 103's just about ... May 2 2016, 06:13 PM
Hans Jan Good spotting,no machining gone on there,just plai... May 2 2016, 09:23 PM
Mueller
Good spotting,no machining gone on there,just pla... May 2 2016, 09:51 PM
396
This is breaking my heart. Not Nickies and now... May 3 2016, 12:46 AM
ThePaintedMan
It is the policy of this community not to defame ... May 3 2016, 08:29 AM
Hans Jan Thank you Mark. May 2 2016, 09:53 PM
r_towle
Thank you Mark.
Of note is how close the studs a... May 3 2016, 09:42 AM
rhodyguy Late to the party. You can see the parting line th... May 3 2016, 01:24 AM
Jake Raby Those are Chinese, cast iron clunkers... Nothing N... May 3 2016, 08:33 AM
Hans Jan Thank you for the support. I feel like I bought a ... May 3 2016, 08:48 AM
JOEPROPER We've been hearing a lot about this Glenn in C... May 3 2016, 08:51 AM
billh1963 I only see one post from Glenn Wright...selling a ... May 3 2016, 09:07 AM
sixnotfour $5500 new German high compression 96mm piston... May 3 2016, 02:24 PM
ericoneal Be sure to screenshot the Craigslist ad before it ... May 3 2016, 02:53 PM
Porschef :WTF:
Maybe that's the engine that was suppo... May 3 2016, 02:52 PM
r_towle ... May 3 2016, 04:50 PM
'73-914kid Those aren't nickies in the picture from the c... May 3 2016, 06:10 PM
396 Not to beat this to death. But if that's what... May 3 2016, 06:40 PM
Mueller
Not to beat this to death. But if that's wha... May 3 2016, 07:04 PM
r_towle Still would be aluminum. May 3 2016, 07:04 PM
r_towle While they certainly may exist, I have not seen ca... May 3 2016, 07:06 PM
colingreene was it Lawrences motor? EMW did do that motor.
and... May 3 2016, 09:22 PM
Mark Henry
an... May 3 2016, 09:47 PM
Mark Henry
[quote name='colingreene' post='2339914' date='Ma... May 4 2016, 01:18 PM
Jake Raby Nickies TM are a trademark of LN Engineering, and ... May 3 2016, 10:02 PM
sixnotfour https://en.wikipedia.org/wiki/Nikasil May 3 2016, 10:12 PM
396 I use Three Bond between the cam towers...as sugge... May 4 2016, 01:58 PM
Mark Henry
I use Three Bond between the cam towers...as sugg... May 4 2016, 02:02 PM
sixnotfour :confused: May 4 2016, 03:36 PM
Hans Jan Earlier this week there was some confusion about t... May 4 2016, 05:24 PM
r_towle Cool for that I guess.
I have used 103 cast cylind... May 4 2016, 05:53 PM
2mAn saw the engine fire picture and have been skeptica... May 4 2016, 05:55 PM
RoadGlue
saw the engine fire picture and have been skeptic... May 4 2016, 05:56 PM
r_towle
saw the engine fire picture and have been skepti... May 4 2016, 06:01 PM
396
saw the engine fire picture and have been skeptic... May 4 2016, 06:22 PM
Hans Jan Sorry, it appears that I have to recall the messag... May 4 2016, 08:00 PM
r_towle If you look at some of the pictures in this thread... May 4 2016, 09:52 PM
PotterPorsche I remember this car was for sale for 9k 2 years ag... May 4 2016, 09:59 PM
ConeDodger Nickies or not and those are not, you don't wa... May 4 2016, 10:09 PM
Mark Henry Pop a head off and measure, there are no head gask... May 5 2016, 05:04 AM
mepstein Go back to the original posters 1st post, second p... May 5 2016, 05:35 AM
396 :deadhorse: :deadhorse: May 5 2016, 08:43 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:11 PM |
