> Replacement Speakers - 1974
orbit398
post May 2 2016, 08:04 PM
Does anyone have any suggestions for replacement speakers for a 1974 model original location. I purchased some from Crutchfield (MTX Audio Coaxial Thunder 68) but they don't fit. thanks
malcolm2
post May 2 2016, 08:29 PM
QUOTE(orbit398 @ May 2 2016, 09:04 PM) *
Speaker pods from 914 rubber work great. You can cut them to fit many different speakers. They look close enough to OEM and take a round speaker, maybe a 7". just remember to order the speaker grills when you order speakers and use them vs. the brittle OEM. The OEM pods are designed for some funky size 5x7 iirc. no such hole pattern in this century either.
http://shop.914rubber.com/Porsche-914-door...m?categoryId=-1
porschetub
post May 3 2016, 02:00 AM
QUOTE(malcolm2 @ May 3 2016, 02:29 PM) *
OP asked about original location,tricky cause they aren't 5 x 7,been there done all that and got frustrated and at a cost,modern speakers don't fit because the magnets are generally too large and won't clear the heater tube hoses.
Not a lot of choices for fit in the original enclosures if you want a reasonable sound.
malcolm2
post May 3 2016, 09:41 AM
QUOTE(porschetub @ May 3 2016, 03:00 AM) *
So where do you think the 914rubber pods go? They replace the brittle, funky shaped Factory enclosures.
or do you think the speakers originally came in the door?
rjames
post May 3 2016, 10:13 AM
I'm made of metal
QUOTE(malcolm2 @ May 3 2016, 08:41 AM) *
I think he meant speakers in the original location- as in the original plastic pods/covers, not in an aftermarket pod.
porschetub
post May 3 2016, 01:43 PM
QUOTE(rjames @ May 4 2016, 04:13 AM) *
Exactly,thank you.
I have AP f/glass ones and 6.5'' blaupunkts,don't think it would be too easy to get a 7'' in them,depends how much larger the housing is than the cone,some makes can vary in that size.
Good luck on the AA ones....200watt and $39.50 (IMG:style_emoticons/default/dry.gif)
orbit398   Replacement Speakers - 1974   May 2 2016, 08:04 PM
malcolm2   Does anyone have any suggestions for replacement ...   May 2 2016, 08:29 PM
porschetub   Does anyone have any suggestions for replacement...   May 3 2016, 02:00 AM
malcolm2   Speaker pods from 914 rubber work great. OP ...   May 3 2016, 09:41 AM
rjames   [quote name='porschetub' post='2339488' date='May...   May 3 2016, 10:13 AM
porschetub   [quote name='porschetub' post='2339488' date='Ma...   May 3 2016, 01:43 PM
rfinegan   What speakers do you have in the PIC? So where ...   May 4 2016, 09:15 AM
orbit398   Found some direct replacements at Auto Atlanta RGS...   May 3 2016, 08:02 AM
DBCooper   Found some direct replacements at Auto Atlanta RG...   May 3 2016, 02:29 PM
napasteve   I would be interested to know if the AA speakers a...   May 3 2016, 09:14 AM
orbit398   I would be interested to know if the AA speakers ...   May 3 2016, 10:31 AM
cuddyk   I would be interested to know if the AA speakers ...   May 4 2016, 12:07 PM
23e Heure   I would be interested to know if the AA speakers ...   May 3 2016, 10:22 AM
jeffdon   I have been thinking that there are a ton of littl...   May 3 2016, 10:48 AM
napasteve   I looked at the AA item and did a bit of googling ...   May 3 2016, 01:26 PM
ripper911   I looked at the AA item and did a bit of googling...   May 3 2016, 03:15 PM
Creamsicle New Zealand   I purchased a pair of factory replacement speakers...   May 3 2016, 02:34 PM
Mikey914   DXI's aren't supre cheap but work well in ...   May 4 2016, 12:17 AM
cuddyk   Here are some pics of those speakers   May 5 2016, 03:59 AM
- Lo-Fi Version Time is now: 5th November 2026 - 09:14 AM
