> What kind of Cylinders are these?, I bought a 914 with Nickies, but not sure what I received.
HansJan
post Apr 28 2016, 08:03 PM
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious.
Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed.
I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions.
Br,
Hans Jan
r_towle
post May 4 2016, 09:52 PM
Custom Member
If you look at some of the pictures in this thread, I believe what they are asking you to measure is the outer diameter of the liner/cylinder where it goes into the head.
That will be the honest outer diameter of the cylinder.
If you measure in between the cooling fins you will be measuring casting material which won't be consistent and won't be a number they could use.
Look at the pics in this thread....there is a 1/4 in tall exposed area on the top of the cylinder that fits into the head. The cylinders don't sit down tight in the heads, so you should be able to get a tool in between the top fin and the head.
Hans Jan   What kind of Cylinders are these?   Apr 28 2016, 08:03 PM
396   Sorry to hear of your car. In regards to your ques...   Apr 28 2016, 08:09 PM
rhcb914   Those are AA cylinders. http://aapistons.com/   Apr 28 2016, 08:11 PM
ThePaintedMan   :agree: At this point, I'd be willing to bet...   Apr 28 2016, 08:16 PM
Hans Jan   Even though this is bad news, you guys are the bes...   Apr 28 2016, 08:35 PM
Valy   The orange silicon tells a lot about who built thi...   Apr 28 2016, 08:35 PM
914Sixer   You will have to disassemble the engine to find ou...   Apr 28 2016, 08:51 PM
Mueller   You will have to disassemble the engine to find o...   Apr 28 2016, 09:00 PM
Mueller   Nickies are machined, those are cast cylinders, I ...   Apr 28 2016, 08:59 PM
rick 918-S   What video? What did I miss? Maybe not the engine ...   Apr 28 2016, 09:05 PM
Racer Chris   Those aren't 103s. The case registers are pro...   Apr 29 2016, 04:56 AM
Hans Jan   Those aren't 103s. The case registers are pr...   May 2 2016, 01:12 PM
jdm914   It might be worth while to have a long talk with t...   Apr 29 2016, 09:18 AM
Mark Henry   It might be worth while to have a long talk with ...   Apr 29 2016, 09:36 AM
Valy   It might be worth while to have a long talk with...   Apr 29 2016, 10:03 AM
Mark Henry   [quote name='Mark Henry' post='2337719' date='Apr...   Apr 29 2016, 10:38 AM
mepstein   [quote name='Mark Henry' post='2337719' date='Ap...   Apr 29 2016, 10:44 AM
jdm914   [quote name='Mark Henry' post='2337719' date='Ap...   Apr 29 2016, 10:54 AM
Mark Henry   If you paid nickies coin for that you have been ho...   Apr 29 2016, 09:24 AM
sixnotfour   If you paid nickies coin for that you have been h...   Apr 29 2016, 10:09 AM
sixnotfour   If you paid nickies coin for that you have been ...   Apr 29 2016, 01:49 PM
sixnotfour   [quote name='sixnotfour' post='2337732' date='Apr...   May 4 2016, 03:38 PM
boxsterfan   Who sold you the car and are they a member here on...   Apr 29 2016, 09:29 AM
iwanta914-6   More about this unfortunate event in this thread: ...   Apr 29 2016, 09:34 AM
Mark Henry   More about this unfortunate event in this thread:...   Apr 29 2016, 09:40 AM
Mark Henry   Point is I've never seen a failure. It was how...   Apr 29 2016, 11:07 AM
JamesM   Point is I've never seen a failure. It was ho...   May 2 2016, 11:46 PM
Mark Henry   BTW just an FYI I've also used both Jake's...   Apr 29 2016, 11:33 AM
iwanta914-6   Well, this thread went a bit off topic... Turned i...   Apr 29 2016, 11:37 AM
Mark Henry   Well, this thread went a bit off topic... Turned ...   Apr 29 2016, 12:01 PM
jdm914   Good point... It is unfortunate that this new 914 ...   Apr 29 2016, 12:41 PM
Mark Henry   Good point... It is unfortunate that this new 914...   Apr 29 2016, 01:28 PM
Puebloswatcop   I think we should all concentrate on finding the S...   Apr 29 2016, 01:13 PM
Valy   @Mark: So did the guy that rebuilt that engine... ...   Apr 29 2016, 01:51 PM
Mark Henry   @Mark: So did the guy that rebuilt that engine......   Apr 29 2016, 02:27 PM
Valy   @Mark: So did the guy that rebuilt that engine.....   Apr 29 2016, 04:59 PM
Mark Henry   [quote name='Mark Henry' post='2337862' date='Apr...   Apr 30 2016, 06:50 AM
Valy   [quote name='Mark Henry' post='2337862' date='Ap...   Apr 30 2016, 04:29 PM
r_towle   @Mark: So did the guy that rebuilt that engine.....   Apr 29 2016, 06:48 PM
Hans Jan   Sorry. I havent visit the site for a few days, and...   May 2 2016, 01:06 PM
r_towle   Well, the best way is to measure the piston diamet...   May 2 2016, 04:52 PM
r_towle   I think Chris is right, the 103's just about t...   May 2 2016, 04:55 PM
porschetub   I think Chris is right, the 103's just about ...   May 2 2016, 06:13 PM
Hans Jan   Good spotting,no machining gone on there,just plai...   May 2 2016, 09:23 PM
Mueller   Good spotting,no machining gone on there,just pla...   May 2 2016, 09:51 PM
396   This is breaking my heart. Not Nickies and now...   May 3 2016, 12:46 AM
ThePaintedMan   It is the policy of this community not to defame ...   May 3 2016, 08:29 AM
Mark Henry   I think Chris is right, the 103's just about ...   May 2 2016, 09:39 PM
396   I think Chris is right, the 103's just about...   May 2 2016, 10:25 PM
Mark Henry   Boy, you even have the ARP case bolts too. Way t...   May 2 2016, 10:38 PM
Hans Jan   Thank you Mark.   May 2 2016, 09:53 PM
r_towle   Thank you Mark. Of note is how close the studs a...   May 3 2016, 09:42 AM
rhodyguy   Late to the party. You can see the parting line th...   May 3 2016, 01:24 AM
Jake Raby   Those are Chinese, cast iron clunkers... Nothing N...   May 3 2016, 08:33 AM
Hans Jan   Thank you for the support. I feel like I bought a ...   May 3 2016, 08:48 AM
JOEPROPER   We've been hearing a lot about this Glenn in C...   May 3 2016, 08:51 AM
billh1963   I only see one post from Glenn Wright...selling a ...   May 3 2016, 09:07 AM
sixnotfour   $5500 new German high compression 96mm piston...   May 3 2016, 02:24 PM
ericoneal   Be sure to screenshot the Craigslist ad before it ...   May 3 2016, 02:53 PM
Porschef   :WTF: Maybe that's the engine that was suppo...   May 3 2016, 02:52 PM
r_towle   ...   May 3 2016, 04:50 PM
'73-914kid   Those aren't nickies in the picture from the c...   May 3 2016, 06:10 PM
396   Not to beat this to death. But if that's what...   May 3 2016, 06:40 PM
Mueller   Not to beat this to death. But if that's wha...   May 3 2016, 07:04 PM
r_towle   Still would be aluminum.   May 3 2016, 07:04 PM
r_towle   While they certainly may exist, I have not seen ca...   May 3 2016, 07:06 PM
colingreene   was it Lawrences motor? EMW did do that motor. and...   May 3 2016, 09:22 PM
Mark Henry   was it Lawrences motor? EMW did do that motor. an...   May 3 2016, 09:47 PM
Mark Henry   [quote name='colingreene' post='2339914' date='Ma...   May 4 2016, 01:18 PM
Jake Raby   Nickies TM are a trademark of LN Engineering, and ...   May 3 2016, 10:02 PM
sixnotfour   https://en.wikipedia.org/wiki/Nikasil   May 3 2016, 10:12 PM
396   I use Three Bond between the cam towers...as sugge...   May 4 2016, 01:58 PM
Mark Henry   I use Three Bond between the cam towers...as sugg...   May 4 2016, 02:02 PM
sixnotfour   :confused:   May 4 2016, 03:36 PM
Hans Jan   Earlier this week there was some confusion about t...   May 4 2016, 05:24 PM
r_towle   Cool for that I guess. I have used 103 cast cylind...   May 4 2016, 05:53 PM
2mAn   saw the engine fire picture and have been skeptica...   May 4 2016, 05:55 PM
RoadGlue   saw the engine fire picture and have been skeptic...   May 4 2016, 05:56 PM
r_towle   saw the engine fire picture and have been skepti...   May 4 2016, 06:01 PM
396   saw the engine fire picture and have been skeptic...   May 4 2016, 06:22 PM
Hans Jan   Sorry, it appears that I have to recall the messag...   May 4 2016, 08:00 PM
r_towle   If you look at some of the pictures in this thread...   May 4 2016, 09:52 PM
PotterPorsche   I remember this car was for sale for 9k 2 years ag...   May 4 2016, 09:59 PM
ConeDodger   Nickies or not and those are not, you don't wa...   May 4 2016, 10:09 PM
Mark Henry   Pop a head off and measure, there are no head gask...   May 5 2016, 05:04 AM
mepstein   Go back to the original posters 1st post, second p...   May 5 2016, 05:35 AM
396   :deadhorse: :deadhorse:   May 5 2016, 08:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:59 PM
