Parts wanted - Brisbane, Australia, 1.8 L muffler system, rubber grommets beneath fuel tank |
DaveO90s4 |
May 5 2016, 04:24 AM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
Dear all, as the title says I'm looking for:-
1. A muffler system to bolt to my 1.8 L single pipe each side triangular flanged three bolt headers. Local shop will make me a system for A$550, but if anyone has a good system reasonably locally I'd be interested; 2. A job lot of rubber 'bungs' for the various holes (no, not the rust holes, the round punched ones) in the sheet metal beneath the fuel tank, including the large 100 mm hole on the front right. Or suggestions where I can buy these locally. Yes, I could import from US, but the freight costs dwarf the pric of the parts themselves. And I'm in a hurry, as always. Thanks all Dave Attached thumbnail(s) |
ndfrigi |
May 5 2016, 08:21 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
I have this after market muffler attouched to the original 75 1.8 Heat exchanger that I only used for less than 200 miles.
If you will keep the 75 or 76 heat exchanger this is exactly you need unless you are planning to replace your heat exchanger to early one. The 100mm hole underneath the fuel tank or along the steering rack you are referring probably the access hole to check the fuel lines? there is no rubber cover for that? but you should have a steering rack (rectangular) metal cover underneath to protect the steering rack and brake system. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:50 PM |
