ground issue maybe? |
jcav |
May 5 2016, 11:39 AM
Newbie Group: Members Posts: 35 Joined: 4-April 15 From: albuquerque/ames Member No.: 18,595 Region Association: None |
In my 1975 914 1.8, I was out driving the car, and all of a sudden when i hit the accelerator the cars power seemed to cut out and if i kept the revs up ut would do fine.
I got the car home fine, and it would start up and idle just find but when i hit the accelerator it wanted to die out. Im waiting for a new fuel injector to come in because i have a leaky one, but not sure what to look at while i wait for the part |
Garland |
May 5 2016, 07:42 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Pulling out on to the main road, under semi hard acceleration, the engine stumbled. It was like the switch was turned off, and the back on. 3 Miles later, same type of acceleration, quit and would not restart. Pulled over. Checked fuel pump, it was priming when the key was turned on. Electric at coil was good. So why won't it start? FI 1.7 Poked around and tried it again, and off I went. Well the rest of the ride when ever I went past 1/2 way with the gas pedal, it would try to shut down. Let off the gas or hard on the gas , and it ran. When I got home I found the accelerator cable when under tension, would just touch one of the leeds on the coil and short out through a pin size hole on the casing of the accelerator cable. Moved the cable a little, and good to go. Same thing happen to me in 05 |
jcav |
May 5 2016, 09:10 PM
Pulling out on to the main road, under semi hard acceleration, the engine stumbled. It was like the switch was turned off, and the back on. 3 Miles later, same type of acceleration, quit and would not restart. Pulled over. Checked fuel pump, it was priming when the key was turned on. Electric at coil was good. So why won't it start? FI 1.7 Poked around and tried it again, and off I went. Well the rest of the ride when ever I went past 1/2 way with the gas pedal, it would try to shut down. Let off the gas or hard on the gas , and it ran. When I got home I found the accelerator cable when under tension, would just touch one of the leeds on the coil and short out through a pin size hole on the casing of the accelerator cable. Moved the cable a little, and good to go. Same thing happen to me in 05 Gotta love that! haha it something so simple that took me a couple of days to figure out and it does not take much at all for it to happen |
Lo-Fi Version | Time is now: 9th June 2024 - 10:02 PM |
